718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
PIWIS 3 Coding Retrofit and Feature Request
Old 07-30-2024, 11:23 AM
  #1096
eharris6919
eharris6919's Avatar
Default Unsure what to do.
I have a piwis 3 and have been playing around on simulation mode. My problem is whete to start at. Far example on changing the blinker from 3 to more. And also updating my pcm I have tried the SD card method but no luck. I have a 2017 cayman with the 4.0 pcm. Any help will be greatly appreciated
Old 07-30-2024, 11:29 AM
  #1097
oscarmelendez
oscarmelendez's Avatar
You can try the DVD. I have it. I can send you a copy for a donation. Last person sent me $20.
Old 07-30-2024, 11:30 AM
  #1098
oscarmelendez
Default DVD upgrade
You can try the DVD. I can send a copy for a donation. Last person sent me $20.
Old 07-30-2024, 11:49 AM
  #1099
718socal
718socal's Avatar
What version is that? I am curious. What version of PIWIS are you using? Please share a screenshot.
Old 07-30-2024, 11:50 AM
  #1100
Westcoast
Westcoast's Avatar
Received 4,694 Likes on 2,731 Posts
The OEM Navigation Retrofit thread has all of the information you should need to get this done, well worth the read!
718socal (07-30-2024)
Old 07-30-2024, 11:53 AM
  #1101
oscarmelendez
Default DVD upgrade
The DVD is not piwi. The DVD is a DVD I bought online for $15. I must bought a pack of dvd's, and a burning external device. Is a dvd for upgrade the pcm. Piwi is other thing, I have also piwi 3 chinese version (clon). You can buy a clone from this contact that is the one who sold mine.Piwis3 seller
https://wa.link/gmuf8t
suzunoki19840418@gmail.com
Old 07-30-2024, 12:13 PM
  #1102
718socal
718socal's Avatar
I think we are all over the place. We tried to help you with the NAV then we are talking about DVD upgrade. Plus the seller you mentioned above already said they could no longer sell. It would be best if you create a new thread and make your recommendation there.
Old Yesterday, 06:25 PM
  #1103
florindi
florindi's Avatar
I want to give a shout out to @718socal for coding my car and providing excellent support. It was a pleasure working with him!
718socal (Yesterday)
Old Yesterday, 07:21 PM
  #1104
mredwin25
mredwin25's Avatar
Any idea what needs to be coded to turn off the headlight startup sequence?
Old Yesterday, 07:54 PM
  #1105
Westcoast
Westcoast's Avatar
Curious why you would want to do this? It is part of the systems check to determine that everything is working correctly.
Old Yesterday, 10:11 PM
  #1106
mredwin25
mredwin25's Avatar
One of my headlights throws an error every time it does these checks, not gonna replace a headlight just for that.
Old Yesterday, 10:26 PM
  #1107
718socal
718socal's Avatar
Don’t you want to get it fixed if it throws an error?
Old Yesterday, 10:48 PM
  #1108
mredwin25
mredwin25's Avatar
Not really, I don’t think I wanna replace a headlight that can still work, they’re pricey too
Old Yesterday, 11:19 PM
  #1109
718socal
718socal's Avatar
Is this a known issue? Any error code you can share in PIWIS?
Old Yesterday, 11:22 PM
  #1110
mredwin25
mredwin25's Avatar
Not sure if this is a known problem but it sure is annoying, you get a flashing yellow headlight symbol on the cluster that keeps flashing nonstop. I’ll scan it tomorrow and share
Quick Reply: PIWIS 3 Coding Retrofit and Feature Request
