718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Official Waiting Room for 718 Spyder / GT4 / GTS Delivery...
Old 08-07-2021, 06:14 PM
  #1126
flynlo
flynlo's Avatar
Originally Posted by TXshaggy
Just ask your SA; imagine your car shows 1 Oct for V900 — Dealer Inventory. Could move right/left based on sale date and certifications.
Not likely correct. My V900 dates are Early September. I think the computer just generates V dates automatically with no regard to the on sale date.
Old 08-07-2021, 06:15 PM
  #1127
flynlo
flynlo's Avatar
How does one find out what ship you are on? My car made it to Emden on 7/30 so I am likely on the Felicity Ace with you guys????
Old 08-07-2021, 06:19 PM
  #1128
Mtnbkrlts
Mtnbkrlts's Avatar
Originally Posted by slilley
Unfortunately, according to Porsche, all our model year 2022 cars are going to be held until October 1st waiting for EPA and/or CARB certification. Does anyone know if they get stored at port, or are they delivered to the dealer where we can see them? I assume it's the former.
Same here for my 2022 Spyder: original V900 delivery date 8/24/21, then slipped to 9/10/21, now sitting at 10/1/21 awaiting EPA emissions certification. Definitely hoping for sooner vs later.
Old 08-07-2021, 06:20 PM
  #1129
TXshaggy
TXshaggy's Avatar
Received 3,764 Likes on 2,127 Posts
I’ll I can tell you is that last year everyone had the same date, 4 Dec.
Individuals occasionally reported earlier system burps, but ultimately they rolled to 4 Dec.
Post up your screenshot. PVSMS seemed to update on Fridays.
Good luck.
flynlo (08-07-2021)
Old 08-07-2021, 07:06 PM
  #1130
LarryLevelGT4
LarryLevelGT4's Avatar
Texted SA and he responded my V900 is 8/27. Hmm...
Old 08-07-2021, 07:16 PM
  #1131
Dan Nagy
Dan Nagy's Avatar
Received 2,219 Likes on 1,117 Posts
Maybe yours is a 2021 model? The 2022 models are the ones being held for EPA certification. I just looked at their website and they don’t have a Porsche 2022 application in their system yet.
Old 08-07-2021, 07:35 PM
  #1132
LarryLevelGT4
Will triple check with SA, but it's Shark Blue which wasn't available MY21. All paperwork says 2022.
It's going to suck if it's being held until October, or later.
ETA --- SA confirmed, 2022.
Old 08-07-2021, 08:06 PM
  #1133
TXshaggy
TXshaggy's Avatar
Don’t know what’s wrong with some SAs, but last year on both 992 and 718 forums people reporting car en route to dealers w/immediate pick-up via SA updates…ultimately we all waited until the “date”. It was almost a daily “my SA” said “this week” … for months.
There is a “date”…hope for all it’s Aug.
Old 08-08-2021, 10:10 AM
  #1134
flynlo
flynlo's Avatar
I had a buddy that made me feel "great". He says, "Your car will be sitting in the port of Houston for a month in the most active month of hurricane season."!!!!
Something I had not thought of. On more thing to worry about.
Shaggy, I am pretty sure you are correct as far as the "date" goes. The "V dates" have lagged through this whole process. And like I said, I bet the computer is not considering the official "on sale" date. And we will likely see those dates rectified over the next few days or weeks.
Old 08-08-2021, 10:16 AM
  #1135
slilley
slilley's Avatar
Your SA can tell you what ship it's on. If your car arrived in Emden on 7/30, that's the date that Felicity Ace left, so you may not be on the same ship. Goodwood was scheduled to leave port yesterday, and that arrives at the Port of Houston just a couple days behind Felicity Ace.
flynlo (08-08-2021)
Old 08-08-2021, 10:29 AM
  #1136
flynlo
flynlo's Avatar
Thanks for the info. I would be good with either of those. I guess it doesn't matter much if the thing is gonna sit in the port for a month anyway...
slilley (08-09-2021)
Old 08-08-2021, 11:25 AM
  #1137
OldJohnBoy
OldJohnBoy's Avatar
Originally Posted by OldJohnBoy
Thanks for your reply. The 2014 Cayman that I traded in today had a flat-six engine also, and I never heard anything like this --- it reminds me of the sound of a diesel engine, just not as loud. Also, the low oil pressure doesn't seem right. For my 2014 Cayman, the owner's manual stated that the oil pressure should always be above 31 psi at normal driving speeds. I checked the owner's manual for my new GTS 4.0 and for the oil pressure it only says keep it above 51 psi at 4,000 rpm --- not much help. As I mentioned above, the oil pressure stayed in the 25 - 28 psi range on my drive home today --- that's seems too low.
I did some checking on the 718 forum and found that high oil temperatures in the engines for the GT4 has been a concern. Apparently, the engines for the GT4 and GTS 4.0 are designed to run at higher oil temperatures and that, therefore, the oil pressure is lower under normal driving. This situation would agree with what I have experienced in my new GTS 4.0 where the oil temperature is running about 10 degrees higher and the oil pressure is running about 5 psi lower than in my previous 2014 Cayman. In one of the posts, a new GT4 owner was so concerned about the higher oil temperatures and lower oil pressures that he went back to the dealer to discuss. He was taken on a test drive in another new GT4 to be convinced that this situation with higher oil temperatures and lower oil pressures is the "new normal."
In regard to the clanging sound that I was hearing in my new GTS 4.0, I have found something that could be the answer. Apparently, the engines in the GTS 4.0 (including those for U.S. models), have Adaptive Cylinder Control which automatically deactivates 3 cylinders under certain conditions to increase engine efficiency and the owner's manual states that this 3-cylinder operation affects engine noise. As mentioned before, the noise that I was hearing appeared to be only at low speeds when slowing down in traffic with the Auto Stop/Stop Function turned off. So maybe this the explanation.
The following 4 users liked this post by OldJohnBoy:
Dan Nagy (08-08-2021), Old-n-slo (08-09-2021), Porsche2014 (08-09-2021), StormRune (08-08-2021)
Old 08-08-2021, 12:16 PM
  #1138
Z06jerry
Z06jerry's Avatar
flynlo, We're also on Goodwood, headed for Halifax, I guess were crewmates.
Old 08-08-2021, 01:30 PM
  #1139
flynlo
flynlo's Avatar
WoooHoooo!!!! Cheers mate!!!
Old 08-08-2021, 02:12 PM
  #1140
Der Tgr
Der Tgr's Avatar
My understanding is that when the *** is off, cylinder deactivation is also off, so you shouldn't hear it in that case.
Quick Reply: Official Waiting Room for 718 Spyder / GT4 / GTS Delivery...
