Official Waiting Room for 718 Spyder / GT4 / GTS Delivery...
#9752
I ordered LWB seats with my recent CGTS spec. My SA said LED PDLS were on his list of non orderable but LWB seats were not. He said I should hear in a day or two if anything on the order wasn't available. I haven't heard anything so hopefully all is good.
Has anyone had any issues ordering LWB seats with their spec?
So not only do I have a car stuck in Emden for 9 weeks now it also doesn't have buckets.
![fp](https://rennlist.com/forums/images/smilies/facepalm.gif)
#9753
Have your SA check again.
My order - accepted and placed in Feb, had LEDs with PDLS+ (plus being the operative part) had the LEDs and PDLS+ removed when they placed it from my demand order - all the way back in August 2021 !
When they asked me to confirm the order after I got the "you won the GT4 lottery" screen (order accepted). I was able to re-ad LEDs with PDLS (no plus). I believe the + may still be UNavailable on some models/many if not all Caymans.
LWBs: I considered but didn't order, but was watching as I was considering. From memory, here's the approximate timing:
Cars where allocations were confirmed by late November 2022 and had LWBs in the order were locked in. After that, they 1. couldn't be ordered and I believe came out of a few orders where allocations were received later (same thing that happened to me with PDLS+).
I saw on Rennlist that folks in the UK, then US and other markets, were able to add LWBs. This came down to the wire (my lock date) for my consideration. My "change freeze" date was 3/13, so they became re-available only the week before (at least in the US). My SA wasn't sure this would really work in the US so actually added them to my config March 10(I really didn't want to mess with my config that close to lock w/o their involvement). Ultimately I drove to dealer (75 miles) to sit in the LWBs and decided against them due to how they fit my back. I'm short and no adjustment on a long drive to a track would have doubtless left me stiff. So that was more or less the LWB timing - if it hasn't changed again more recently.
I stopped watching much after my lock date.
I believe your SA missed the nuance that LEDs with PDLS (no plus) became available again last Feb, or something since had changed again.
Hope this helps!
ADS
Hope this helps!
ADS
#9754
Thanks ADS
I didn’t know there are LED PDLS +. My SA did say the + so maybe I could have ordered LEDs. That’s annoying.![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
im going to try and confirm with my SA today if I get LWB If I can’t get them, there’s no reason for me to buy the car.
#9755
I moved forward without LWB as it was on stop order.
Now going to have to pony up 10-15k IF they can be found second hand.
This process continues to disappoint.
#9756
If you're before your lock date I expect you can add LEDs, or LEDs w/PDLS, if you want them.. ADS
#9757
If I ever start towing my GT4 to tracks, I'll probably add buckets with adjustable backs, found a couple I like. The LWBs are about $3260 more than 18 ways.
The LWBs are the coolest looking seats, no doubt. But - I can build a nice set of reclining seats for just the difference; I think the Corbeau's I was looking at have an option that would closely match my red stitching, you can add heated elements, etc. They won't mimmick LWB/OE look, but will look really good, and will have better function for non-racers.
If I can find a certified set of belts what will work with the 18 way tombstones, I'll be good. Won't have anti-sub, but will keep me in place and be as safe/safer than the OE belts.
ADS
ADS
#9758
My car is supposed to be on truck out of port Houston on Sunday 5/21 (if that is even possible). I'm in central KY. Anyone else in the Ohio/Kentucky/Indiana Tenn/Arkansas path with the same date?
ADS
ADS
#9759
Originally Posted by adsingl;[url=tel:18811546
18811546[/url]]If you're before your lock date I expect you can add LEDs, or LEDs w/PDLS, if you want them.. ADS
it was an unusual situation and I had to lock that day.
it’s weird tho because that was 5/16 and TYD has 5/4 as the lock date for step 2. I don’t have any faith in the date since the date for step 1 is 5/8.
I don’t really care about LEDs too much. I was going to order them for the look not so much for a better light
adsingl (05-19-2023)
#9762
#9763
my SA sent me a build sheet today and it’s at V220 so think it’s good to go.
Not crazy about the disclaimer tho.
The following 8 users liked this post by Billt613:
321_Launch (05-22-2023),
adsingl (05-22-2023),
kmh0277 (05-19-2023),
l30thelion (05-20-2023),
MrFunk (05-21-2023),
and 3 others liked this post.
