Let's talk about cheap exhaust valve mod options!
#541
First and foremost, thanks for coming up with this low cost and innovative solution to Porsche's obnoxious valves! Would you recommend I lower the collars a bit based on the picture I have posted? I love the sound where it's at now, and I think I have placed the collars low enough to allow for some very subtle opening/closing. Thanks again!
I found lowing them a bit does not impact the ‘full open’ experience from having the collars all the way to the top . . . and provides some theoretical peace of mind that a little play still occurs that will prevent the stems from seizing. I doubt the stem would ever seize in place but, again, just a little theoretical peace of mind.
Avera
#542
exhaust collar modification
981Kman and I did the mods on our cars at the same time, which allows for some travel of the valve assembly, and to the best of my knowledge, neither of us has experienced any negative issues of any sort as a result of performing this relatively simple modification.
#543
I think if you lower your collars from what is shown in the picture you will not hear much change in sound, yet allow the valves to move a little more. All I can say is play with it and find the position that YOU like best.
MrFunk (10-10-2023)
#544
kudos to this fella for putting this together, not sure if you are a member on here
amazingly detailed explanation which really helped me see what was involved
I have to confess for a non-handy type, it looks a little intimidating to be able to accomplish under the car with no lift.
I also find myself leaning towards the disconnect lines and plug method for reversabiity...getting these collars out later would seem to be quite the feat if you wanted to revert to stock
I also have to confess I am starting to wonder if either method is worth the hassle, if you are just going to leave it at that for now...seems like having the valves open all the time is really just a subtle difference in overall enjoyment of the car on an otherwise stock exhaust
downshifted (02-18-2024)
#545
I decided to put the collars on the stock exhaust system while I figure out my exhaust (most likely Kline in the next couple months). The car currently has no OAP's..., it's fully stock... I placed the collars favoring the more conservative setting... probably 5mm from most conservative (all the way down). I can hear a change in volume still when the valves open, but in the "closed" position I now have just a bit more exhaust note... I don't particularly like the tone of the OEM exhaust which is why I didn't want them more open all the time... I think this more conservative setting works well with a completely OEM system. My $0.02
#546
...........I have to confess for a non-handy type, it looks a little intimidating to be able to accomplish under the car with no lift.
I agree that locking the valves full open all the time, by plugging the vacuum lines or by mounting the collar up against the actuator mount is not the best option. While the YouTube video shown above is nicely done, it misses one of the main benefits of my Collar Mod - that is, the adjustable feature to allow the valves to be held open at various levels. So you can set the exhaust sound to your individual taste - 30%, 50%, 80% open.... anywhere that sounds best to you. The video demonstrates the Locked Full Open option, yet does not explain that other positions will provide other exhaust notes, and you can still have some exhaust note attenuation without the obvious "step" around 3700 RPM. If you are going to lock the valves full open all the time and live with the Drone, you might as well just plug the vacuum lines....... Kind of misses the cool feature of the Collar Mod - its adjustability.
The following 6 users liked this post by 981KMAN:
3TonP (10-11-2023),
baege (10-11-2023),
fasteddie99 (01-13-2024),
slilley (10-11-2023),
StilettoPat (10-11-2023),
and 1 others liked this post.
#547
Adding or removing the Collars are quite ease. Takes about 5 minutes each side with the car on the ground. So the collar mod is easily reversible and adjustable as to valve position.
but I am curious as to why you say you might as well plug the vaccum lines as opposed to using the collars if you are going to have the valves open all the way all the time?
#549
#550
#551
Possibly some blue Loctite if you need a little extra reassurance.
#552
The advantage of the Collar Mod over plugging the vacuum lines is the adjustability of the Valve Opening level. You can eliminate the sound change @ ~3700 RPM, and most of the Drone by letting the valves partially close, and not keeping them at 100% open.
The following 3 users liked this post by 981KMAN:
#553
Possibly you did not tighten the screws enough or left any packaging/storage lube on the screws before installation? I have not experience any movement or loosening of my collars (~9K miles), yet I used the Black Oxide versions as they grip the shafts better.
#554
I installed these on my OEM & Kline, without any issues with them moving or falling off.
https://a.co/d/3VLSVSO
#555
https://www.youtube.com/watch?v=sklulqAUAVs&t=836s
Wow. That is a lot of video and a lot of talking for something that is very simple and does not require removal of the rear section. Great for someone with almost zero mechanical ability, I guess, but a bit of overkill. We're talking two screws here.
I tend to agree that if what you are seeking is totally open valves all the time, the easiest method is to simply disconnect and plug the vacuum line(s). For me, wide open all the time was just too much (too loud at times when I just want stealth) and I ended up taking the collars off and just sticking with the Akra OAPs. YMWV. But I am also still toying with the idea of trying to introduce a vacuum delay valve that will make the opening and closing a much more gradual thing. The stock setup is way too flip of a switch for me and doesn't seem tied to throttle pressure like it should be in my opinion. I want my exhaust to get louder as a result of more demand from my right foot and not as a result of a solenoid opening a couple of valves.
