Cargraphic valve control unit
#286
My apologies, I clicked in via an email thinking this was the 992 thread. We'll take a look at the 718 shortly and see if we can come up with a similar solution!
Flat 6 Motorsports
Porsche Aftermarket Specialists
www.flat6motorsports.com
Instagram / Facebook / YouTube
Flat 6 Motorsports
The following 3 users liked this post by Flat6Motorsports:
#288
I plan to move the CG box to a location where I can get its antenna a clearer shot from the Homelink antenna, possibly feed it through the firewall where the sound symposer opening is and into the passenger compartment.
#289
Mine would for the most part work but every now and then it wouldn't the 1st try and push of the button on the overhead console.
I had other work being done so Nick (Shop-Foreman) said he would take a closer look at current location and see if he felt like there was a better location ???
Below are some images Nick took as he relocated it and after he did the New Location it does work 1st Time every-time !!!
This is where Nick originally installed the Cargraphics valve-controller below.
Below is the Original 1st install LINK.
08-01-2022, 01:12 PM
Cargraphics Mode 2 valve controller, BMC Performance intake filters, SOUL OAP install
https://rennlist.com/forums/718-gts-...l#post18279624
Read Nick's comment on Relocating the Cargraphics vale-controller at the bottom of invoice.
12-08-2023, 07:35 AM
2nd year service report below and this Post includes images that Nick sent me of ...............
Relocating the Cargraphics "Valve-Controller" to a different location and it works PERFECT after the Relocation !!!
Simply roll the page down to see the Relocation-Images of the Cargraphics "Valve-Controller".
https://rennlist.com/forums/718-gts-...l#post19154834
Hope the above helps with your Reception issues,
Terry
#290
Terry, my CG controller is in about the same location, outside of the engine compartment and along that side, a little ahead of where you show the wire... reception is still not all that good for me. (Spyder)
#292
#293
#296
I m looking to buy a Cargraphic valve controller and maybe resonated OAP
I disconnected the valve hoses to keep the valves always open to see if I d like the sound
I think that it s a nice mod especially if you can put it back to standard with the CG controller when you want
The valves open are especially nice when you downshift and when used in manual mode
I found it a bit less nice when in automatic as in that case with the gearbox going in higher gears at lower speed the noise is more often in a range that is not really nice and close to slight drone
With aftermarket OAP standard could be better
