718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Gear 1-2 grind
Old 02-24-2022, 07:13 PM
  #901
unclemat
unclemat's Avatar
You guys make me want to find a manual 4.0 for a test drive.
I drove a manual S 2.5 and seemed "fine" but I don't remember being wowed. But it was a short test drive, but included local streets and highways. Hmmm.
Old 02-24-2022, 07:17 PM
  #902
UncleDude
UncleDude's Avatar
Received 5,452 Likes on 2,233 Posts
Great gear box, I highly recommend tracking one down before your freeze. It probably is the same box as the 2.5, but when you've got that 4.0L hooked to it I bet it feels a bit different (I drove a 2.5 but I can't remember the specifics). The auto blip makes it even more fun...., please don't let this thread sway your decision. PDK is awesome, but don't get it because of a few gear grinds.
Old 02-24-2022, 07:19 PM
  #903
Bob Z.
Bob Z.'s Avatar
Received 3,455 Likes on 2,359 Posts
Anyone on the fence about getting the manual needs to drive one before opting for a PDK based on this thread.
pcarGTS4.0 (02-24-2022)
Old 02-24-2022, 07:59 PM
  #904
AdamIsAdam
AdamIsAdam's Avatar
Received 4,040 Likes on 1,750 Posts
Agreed. I personally only want a manual on all my toys, and on my daily drivers too, but that's getting harder to find. Dedicated race cars excluded.
As for shifters, it's fine, just never going to be as direct as something without cables. I might upgrade the shifter in the future, once I'm sure there are no issues with the tranny. But for now, it's fine.
Overall, I am loving it! I'm just about at 1k miles. Soon I'll change the oil and start to give it the beans!
Old 02-24-2022, 11:37 PM
  #905
patdonahue
patdonahue's Avatar
I have just turned 1200 miles on my CGTS 4.0. Never a hint of a grind but I do not try to speed shift. I drove a 2.0 PDK Cayman as a loner for a couple of days and thought the gear box was impressive. Having said THAT if you are getting a 4.0 CGTS or BGTS this may be one of your last chances to own a manual tranny with a larger N/A engine in a Porsche. Just my opinion.
Old 03-01-2022, 03:07 PM
  #906
scooter100
scooter100's Avatar
My car is at the dealer but always mention the grind to ensure PCNA knows about it. I have definitely had fewer of them but did have one a few weeks ago during a very leisure slow shift so thought I would mention it again when I dropped the car off. It seems like Porsche has finally published something on the subject… curious about people’s reaction:
In the event of a complaint, a balancing weight can be retroftted on the manual transmission.
Replacing the manual transmission will not correct the problem because this is not a manual transmission fault.
Please note that retrofitting the balancing weight changes the vehicle's shift feel. As a result, shifting can then be perceived as less sporty than before and is then comparable with the shift feel of the 718 Boxster/Cayman GTS 4.0 (982).
On the 718 Spyder/Cayman GT4 (982), the shift feel was deliberately adapted to a sportier setup than on the 718 Boxster/Cayman GTS 4.0 (982).Inform the customer about this before retrofitting the balancing weight.Also inform the customer that retrofitting the balancing weight cannot be invoiced under the new vehicle warranty or PAW (Porsche Approved Warranty) as this is not a fault.
The following 3 users liked this post by scooter100:
omar0022 (03-01-2022), patdonahue (03-01-2022), UncleDude (03-01-2022)
Old 03-01-2022, 03:19 PM
  #907
AdamIsAdam
AdamIsAdam's Avatar
Originally Posted by scooter100
... It seems like Porsche has finally published something on the subject… curious about people’s reaction:
WOW! Hold the phone! I'm interested in knowing more about this. I wouldn't think this has anything to do with synchro grind, but now I want to know if I can REMOVE the balancing weight on my CGTS 4.0 to make it feel "more sporty." I wonder what the difference is, exactly. Both in feel and function.
Does anyone have experience with both a GTS and a GT4/Spyder for comparison purposes?
And where exactly is this balancing weight located? Tranny? linkage?
Do you have a TSB number or something that you can share?
Old 03-01-2022, 03:23 PM
  #908
Bob Z.
Bob Z.'s Avatar
If someone decides to have this change made be sure and post your thoughts, as well as the cost, time to add it, etc.
Old 03-01-2022, 03:40 PM
  #909
UncleDude
UncleDude's Avatar
Interesting development - you SOL for warranty claims. I wonder if the GT cars have more or less weight? I drove a GT4 but never really noticed the difference, other than the shift lever height.
Last edited by UncleDude; 03-01-2022 at 05:49 PM. Reason: not sure why it thought I swore
Old 03-01-2022, 04:39 PM
  #910
scooter100
scooter100's Avatar
They didn’t send me the TSB #, just the text I pasted above. It’s $750 to install. At least IMO, something still doesn’t feel correct.
Old 03-01-2022, 04:55 PM
  #911
patdonahue
patdonahue's Avatar
So, there is a subtle difference in the mechanicals of the GT-4 box vis-a-vis the GTS 4.0?
Old 03-01-2022, 05:00 PM
  #912
AdamIsAdam
AdamIsAdam's Avatar
Did you have the work done? If yes, can you describe what was done? It seems that they were going to install a weight, but to what part?
Old 03-01-2022, 05:16 PM
  #913
scooter100
scooter100's Avatar
I did not have the work done. I don’t want to be the Guinea pig. When I pick up the car in a few days, I will try and get more info.
Old 03-01-2022, 05:24 PM
  #914
AdamIsAdam
AdamIsAdam's Avatar
ok, that would be great. Maybe installation instructions too. Snap a photo of them if need be.
Old 03-01-2022, 05:38 PM
  #915
Westcoast
Westcoast's Avatar
Received 4,701 Likes on 2,736 Posts
Originally Posted by patdonahue
So, there is a subtle difference in the mechanicals of the GT-4/Spyder box vis-a-vis the GTS 4.0?
FIFY... My guess is that all of the MT's behind the 4.0l's in the 982 are mechanically the same.
Originally Posted by UncleDude
Interesting development - you SOL for warranty claims. I wonder if the GT cars have more or less weight? I drove a GT4 but never really noticed the difference, other than the **** lever height.
The GT4/Spyder have what is essentially a Short Shift Kit installed (SSK). I did the same change to my 981 GTS and there is a definite difference in feel between the two shifters.
This balancing weight will be something else. Personally, I am fine the way my car shifts...
Quick Reply: Gear 1-2 grind
