New Motor Mount Design: adjustable and rebuildable
#34
Climate control? We already have motor mounts from Volvo that work brilliantly.
#35
#39
Basic Site Sponsor
Basic Site Sponsor
Very nice!
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#40
Actually, I am not using Solidworks right now. I have been using SpaceClaim. I kind of like it, take a bit of getting used to the quirks, but its a nice and affordable solution. Its a direct modeler, so I can easily modify drawings without a history tree.
Seems like most software will do a native 3D PDF export, even my cheap seat of Aliibre Personal does it.
Rod, I will try and get in touch with you tomorrow.
Hans
Hans
#41
Rod Kubis got in touch with me, and had some great ideas on how to make a less expensive version of the mount. It would reduce the machining cost significantly, and could even be a bit easier to service. It does remove some of the adjustability features, but would make retail price very competitive when considering Volvo mounts.
I see there being two versions of replacement mounts - a full "race" mount that would have provisions for height adjustment, complete with shims or drawings for shims, and then a simplified version of the mount, using the same inserts, but non adjustable set at stock height.
We are nailing out the details, but I am still committed to having physical prototypes next week.
Hans
Hans
#42
I have known Hans for some time and we have conversed about many issues on and off the forum. I have agreed to help him out with the engineering by doing some calculations for him and doing up the design. He should have prints by Monday and prototypes by the end of the week.
I do need stock motor mount height unloaded to finish this off if someone could get that, please.
#43
What part for measurement? To the end of the threaded rod?
#44
Also, How much the threads stick out of each end.
Tape measure when you place straight edges across said surfaces should suffice. (two rulers and a tape measure)
I am partial to millimetres, but am fluent in inch as well.
#45
I will attempt to break those out tonight.
BC
BC
