New Motor Mount Design: adjustable and rebuildable
Taking a page from some other great designs out there, I have modeled a new motor mount for the 928, and a local shop has agreed to make a small batch for me at a reasonable price. They will fall in between the price of Volvo mounts and the OE Porsche mounts.
It is a rebuild able design, with two molded polyurethane inserts. These inserts are already being used in motor mount applications, and have been well tested. However, other material could be cut via waterjet and inserted, including 60 or 90shore durometer butyl rubber sheets, or any number of other isolators. This also allows some tuning of the height. This is designed to have an approximate stock height.
The locating pin in the bottom is a grub screw, so can be installed or removed depending on your application. Additionally, the mount can be "preloaded" by screwing the top and inserting the soft-tip locking setscrew allowing further tweaking of the mount. Hardware is all stock metric, but the nature of the mount allows use of other size fasteners if desired.
The first set of test mounts getting cut out next week.
I am attaching a 3D PDF which will allow you to view the part in 3D, remove layers and components to see the guts of the mount. I have a different design that has a lot more adjustment, but requires custom poly inserts. I may make that one for track/motorsport applications, but the cost of either tooling the isolators, or cutting from sheet stock (lots of scrap) would make the mount cost more than I would like. With these standard isolators, replacements for a rebuild (if necessary) would be less than $20/mount.
Thanks,
Hans
Thanks,
Hans
Hans brought a working model of this to the last 3rd Coast and I was impressed with it. Can't wait to see how it's been refined.
Basic Sponsor
Can't wait to sell it - way to go Hans
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Inventor
Cool!
Sure, now that I just popped some Volvo mounts in the '80 a couple weeks ago ;-)
These look awesome...and the '86.5 will need mounts too! Great job - it's just so awesome to see all these amazing parts being developed for our cars.
Inventor
I could see installing a firmer doughnut on the right lower, and left upper.
Hans, you never stop amazing me with your talents. Excellent idea, and design.
Climate control?
