Spyder/Cayman R Discussions about the 987 Spyder/Cayman R (2011-2012)
Spyder Bitten. When Does Obsession Become Insanity?
Old 02-22-2011, 12:32 PM
savyboy
savyboy's Avatar
Default Spyder Bitten. When Does Obsession Become Insanity?
June 30 Update: Things are now back on track with MovIt!
For the three people that read this forum...here is a teaser...full write-up in the next week. It's been a busy winter.
Enjoy
Old 02-22-2011, 01:04 PM
MechanicalEng
MechanicalEng's Avatar
WOW, are those aftermarket PCCBs?? why didnt you go with OEM?
That Capristo Exhaust looks nice
Old 02-22-2011, 01:12 PM
zellamsee
zellamsee's Avatar
Subscribed.
Old 02-22-2011, 01:44 PM
savyboy
savyboy's Avatar
They were OE PCCB. Rear rotors cooked after track days. Porsche OE PCCB rotors are a thin smooth layer glued onto a fragile, rough, carbon core. The MovIt rotors are from a different manufacturer and are monolithic, very strong and durable. Expected to transfer to and last the life of several cars.
More details later.
The Capristo system? 39lbs lighter...right off the sides and *** where it counts the most. It incorporates an electronic backpressure sensor to activate the exhaust valves thereby preserving low end torque while allowing high rpm free flow. An elegant and well engineered solution.
Old 02-22-2011, 02:02 PM
Alan Smithee
Alan Smithee's Avatar
Looking forward to your thoughts. The only two areas that could use some improvement, IMO...engine sound and brakes.
Old 02-22-2011, 02:07 PM
n2cars
n2cars's Avatar
As one of the three readers I can't wait for your write up :-}
Old 02-22-2011, 02:13 PM
Tuscany964
Tuscany964's Avatar
+1
Old 02-22-2011, 02:43 PM
paver
paver's Avatar
Cool wheels too!
Old 02-22-2011, 04:01 PM
Marine Blue
Marine Blue's Avatar
Wow....drooool!
I'm also looking forward to reading the full review.
Old 02-22-2011, 08:18 PM
Polarporsche
Polarporsche's Avatar
Very nice, looking forward to reading the complete write up. I see a few Tarett parts in the pic's, first class all the way.
Old 02-22-2011, 09:47 PM
cvazquez
cvazquez's Avatar
Can't wait for the readers digest. : )
Old 02-22-2011, 11:13 PM
Periokid
Periokid's Avatar
More info on the Brakes!!! Please.
Old 02-22-2011, 11:30 PM
savyboy
savyboy's Avatar
Whew, finally fired it up tonight. Exhaust install, done right, takes a good bit of time and effort. Set to "Open" exhaust is just flat-out crazy. Banshee howl (inside the shop). Set to "Cruise" and it's like a purring kitten.
Too tired and still snowy roads here so full test drive tomorrow. Then a thorough wash and some decent pics. A lot of work went into this car over the past 9 months. Much of it I did myself. Lot of trial and error on suspension and settings. Goal was better than OE when tracked yet fully streetable.
Lost weight, gained power and gave it reliable freight train brakes that should never need maintenance except for once every two year pad changes.
Old 02-22-2011, 11:35 PM
savyboy
savyboy's Avatar
Thanks Russ. GT3 lower control arms. Monoball ends. Bump-steer adjustable toe control arms with spherical ends. Solid, adjustable, caster pucks. Tarett drop links. Custom spec rear sway.
Old 02-22-2011, 11:56 PM
Polarporsche
Pete, your Spyder should kick butt on a tight track, any chance you'll be dropping by Spring Mountain this coming weekend? It would be very interesting to see the Spyder in action.
I'll be sharing a BMW track prep car with a few buddies at SM this weekend, the trip with our cars in the transporter didn't pan out, should be an interesting weekend in the BMW instead of my GT3.
Quick Reply: Spyder Bitten. When Does Obsession Become Insanity?
