Spec Boxsters For info sharing on this exciting new class
Calling all SpecBoxers...
Old Jan 21, 2012 | 08:07 PM
  #166
mglobe's Avatar
mglobe
The Penguin King
These are what I'm using for my SP996. I'm not sure what length you need for the Boxster.
http://www.race-studs.com/servlet/th...27-race/Detail
Old Jan 22, 2012 | 05:46 PM
  #167
Werkstatt's Avatar
Werkstatt
Former Vendor
Call Mac at CDOC, he was our hookup for the correct wheel studs. He can pull up correct size from past orders.
Old Jan 22, 2012 | 05:51 PM
  #168
J richard's Avatar
J richard
Anyone have an update on NASA spec box rules for 2012?
Old Jan 23, 2012 | 09:49 PM
  #169
38D's Avatar
38D
Ok, its not done yet, but here's the pickup, filter and pump for my transmission cooler setup. As I said earlier, my goal is to have this be "part of" the transi so it does not need to be removed when taking the trans out of the car. I still need to finish mounting the cooler, plumb the cooler, install the re-entry point, wire up the pump, and get some heat shielding in place. Once done I'll post a more complete write-up with better pictures.
File Type: jpg
Old Jan 24, 2012 | 09:41 AM
  #170
mjj0000's Avatar
mjj0000
Looks nice but, with the filter on the suction side of the pump, I'm wondering what will happen when the pump tries to run with cold trans fluid?
Could one eliminate the filter?
Old Jan 24, 2012 | 09:13 PM
  #171
38D's Avatar
38D
Simple solution...I'm not going to run it when the fluid is cold . I will either manually turn it on after a few laps, or if I am able to get my data system in this year use a temp based trigger to turn on the pump.
You could eliminate the filter, but then any debris would likely damage the pump.
Old Jan 26, 2012 | 09:37 AM
  #172
Streak's Avatar
Streak
Perfect Angel
Any word on Nasa rules for 2012? I keep checking but all I see are 2011 rules.
Old Jan 26, 2012 | 12:23 PM
  #173
txhansen's Avatar
txhansen
I believe NASA only updates date etc when they change. I glanced at the spec 944 rules and they are from 2010. Hopefully you will get others to join you at a NASA event. In TX we cannot get people to run NASA events for some reason.
Old Jan 26, 2012 | 01:09 PM
  #174
Streak's Avatar
Streak
Perfect Angel
Last I heard was that there were changes. Specifically tires/wheels. Some other things like lexan and something about an air thingy on the engine.
I ask because I'm selling used my tires from last season and I have a fresher set of shaved 888 I can keep if I need to.
Old Jan 26, 2012 | 05:16 PM
  #175
J richard's Avatar
J richard
I'm protesting all air thingys...
Old Jan 26, 2012 | 05:46 PM
  #176
Streak's Avatar
Streak
Perfect Angel
There was a dealywhapper too but I think I'm ok without that
Old Jan 26, 2012 | 11:24 PM
  #177
J richard's Avatar
J richard
My region allows dealywhappers but only if your car is pink...
Old Feb 1, 2012 | 12:18 PM
  #178
Chris M.'s Avatar
Chris M.
Originally Posted by limey940
Thanks, any idea on the SE tracks, anyone?
thanks
In 2011 there was 1 at VIR, 1 at CMP, 1 at Road Atlanta, 0 at Roebling, and there is no club race at Barber.
Old Feb 6, 2012 | 11:08 AM
  #179
jittsl's Avatar
jittsl
In an attempt to save weight I installed a Braille 2015 battery in my SpecBox. I now spend most of my life with an inadequate charge to start my car. It just doesn't seem like enough battery for the job. Before I throw it out and go with a Oddysey PC925 (which i run in my 911 and never had an issue) I thought I would ask:
Does anyone else run a Braille in their SpecBox and does it give them issues?
Thanks,
Old Feb 6, 2012 | 11:51 AM
  #180
C4 Pazzo's Avatar
C4 Pazzo
I run an Odyssey PC680 with no issues, as long as I don't leave the key in the ignition when it's sitting. I know at least one of the NorCal guys with a Braille has to use his battery cutoff switch over night.
