Calling all SpecBoxers...
#106
I have a couple 5 speed transmissions for sale, some just rebuilt with zero hours, one of those with one weekend, with the ports for cooler already welded on if anyone is interested.
#107
Ok, how about another topic to discuss:
The SP996 guys in Texas have been talking amongst ourselves about allowing a specific floating rotor assembly. Our philosophy is generally to not allow changes to the spec that are aimed at performance enhancement, but we are thinking that over a couple of years (or maybe just one year) the floating rotors will give lower running costs due to decreases in rotor cracking, and also lower replacement costs (once you get over the one-time upgrade cost).
Probably not as applicable to SPB, but I suppose it could be.
Comments?
Comments?
#108
The Penguin King
I've tried slotted rotors (DBA) in my SP996 and they cracked just as quickly as the perforated ones. I would expect the SP996's to be much harder on brakes than SPB given the greater weight and greater speeds, so the two classes would not necessarily have the same results or need the same rules.
#109
Floating setup won't fly in the rules as they are right now. I'm looking for input for possible rules change in the future.
#110
#111
Eric, you're having longevity issues even with the trans cooler? I guess it's no silver bullet then... Arg..
What is the weakness of the box?
I've run cross drilled zimmermans on my rsa (2750lbs) for years w/orange &yellow pagids with very little cracking as well. Did have some pad Transfer. I know some guys have real issues but not sure they aren't knockoffs brands...
#112
We could build a stronger 3rd gear but it would be 0.01 off the ratio and figured I'd get in trouble so we just replaced it with new.
The displaced synchro ring we think is overengagement and we installed a stop on the sifter rod/console itself to limit the engagement into third gear.
We machined a couple of aluminum detent pieces that are identical to the plastic is shape/size etc.
I did find some steel pivot pins that I have been unable to break.
So some improvements were made, but it was still a delicate box when pushed really hard and abused, which I'm good at
Lots of people run these boxes without issue, but the podium guys were bringing spares with them in the trailer.
#113
Eric, clean looking install of the trans cooler. I'll post up pictures of mine once its done. My goal is have it be part of the trans, in other words, when you drop the trans, not have to disconnect any lines. We'll see if it works!
#114
Colin,
I definitely want to see how that turns out. Cool idea.
#117
#118
One I get all the trans cooler parts, I plan to do a complete write up of the install. Assuming my idea works, it should turn ok pretty well. The main decision I had in the design was where to locate the cooler. From what I know, it does not require much air flow over the cooler to get the temps down quite a bit. In the mid 90s, I took the Jerry Woods engine and trans rebuilding class, and he discussed how you really just needed to get the fluid out of the case. In fact, he typically used an old style trombone cooler, and said it was plenty effective. Anyway, we'll see how my idea works out .
