991 GT3, GT3RS, GT2RS and 911R 2012-2019
991 GT2RS
Old 06-11-2017, 10:18 PM
  #1531
sgroer
sgroer's Avatar
Received 1,018 Likes on 283 Posts
From instagram Better shot WOW!!! Note I cropped out the hot chick to eliminate distractions. Those aren't vinyl stripes, that's exposed carbon fiber
Old 06-11-2017, 10:22 PM
  #1532
Warren99
Warren99's Avatar
I know it's the angle and lighting but this pic makes it look like it's sitting pretty high off the ground.
I can't wait to see official pics of this beast in actions, especially in a different color. Congrats to the lucky ones getting allocation.
Old 06-11-2017, 10:30 PM
  #1533
Tioga120
Tioga120's Avatar
Sort of a built in front canard dealeo with venting right behind it. Wonder if its tied into the hood ducts somehow?
Also remember seeing tape over the fender vents with the car in desert and it appeared higher than 1RS. These carbon vents are defiantly higher.
One pic of the driver headrest looked like cursive script-cant make it out. Maybe its just blurred for a reason.
Old 06-11-2017, 10:35 PM
  #1534
sgroer
sgroer's Avatar
interesting it has a cage. Would love to see that in the US.
Old 06-11-2017, 10:44 PM
  #1535
ipse dixit
ipse dixit's Avatar
Received 11,782 Likes on 5,143 Posts
Anyone know the DIN or curb weight?
Old 06-11-2017, 10:53 PM
  #1536
porscheflat6
porscheflat6's Avatar
Man I hope I can get one!
Old 06-11-2017, 11:41 PM
  #1537
RennOracle
RennOracle's Avatar
The rear looks too weird, mostly the exhausts and that weird center diffuser. Not a looker on a light color, but it will be a beast.
Old 06-11-2017, 11:43 PM
  #1538
RennOracle
RennOracle's Avatar
That canard is a hole to reduce pressure from the bumper and heat from the radiators.
The hood ducts redirect air to the brakes, they are brake coolers.
Old 06-11-2017, 11:55 PM
  #1539
RennOracle
RennOracle's Avatar
Originally Posted by Petevb
Someone said similar downforce to the GT3 RS. Doesn't look like it to me- looks like a bunch more. Peak downforce maybe isn't greater- if they're smart they're dumping it with the adjustable rear diffuser at speed (they probably needed to prevent suspension compression at ~210 mph). I'll bet heavily it makes a bunch more downforce everywhere else though. Rockers, splitter, etc...
When there are more and bigger 'spoilers', peak downforce will always be bigger, plus there are more and bigger air extractors, mainly the bumper extractors from the radiator and the ones on the back, plus the diffuser and the rear bumper extractors that are noticeably bigger.
There will be more downforce at every speed, that I can bet you.
Old 06-12-2017, 12:14 AM
  #1540
erikerik
erikerik's Avatar
looks like the fender vents are more aggressive as well.
Old 06-12-2017, 12:20 AM
  #1541
Petevb
Petevb's Avatar
The above is not necessarily true if they are using active aero, which patent filings have suggested they will do. They could stall both the diffuser and the front splitter with active aero or even adjust wing angle at which point a lot bets are off.
The air exits just in front of the front wheel well should help reduce that high pressure area and improve front downforce, but that would also be easy to stall.
If they don't cut downforce the GT3 RS aero package would be making 1000 lbs of downforce at 211 mph. The GT2 RS would probably be more like ~1300 lbs with the more aggressive elements seen here. That in turn would require heavier, lower performance tires with a higher load-rating, higher rate suspension springs to maintain ride-height, etc. Technically they would be much better off limiting downforce from ~150 mph up, as it would allow them to significantly improve performance at both low and high speeds.
To what extent they have gone that direction remains to be seen, but technically it probably makes sense to accept the extra complexity given the forces they are dealing with.
Old 06-12-2017, 12:35 AM
  #1542
tcsracing1
tcsracing1's Avatar
This car will be extremely quick.
Old 06-12-2017, 12:47 AM
  #1543
laranja
laranja's Avatar
First reveal at MS gaming preso!
I'm betting Shmee gets an early delivery too
It's all about the pageviews...
I gotta think this is why they put AP out there a week
ago with a "prototype". They probably cut the deal
on the first reveal
with Microsoft after they'd scheduled that AP marketing
tour.
Old 06-12-2017, 01:20 AM
  #1544
jo_ker
jo_ker's Avatar
don't get me wrong - but for me this was a poor launch.
viewing angles, exposure, stage, generally the pictures... it would have deserved a better one.
further on: i would have prevered a new color combo and more aggressive looks.
somehow i feel to prefer the look of the .1 GT3RS.
lets wait for more pics and technical stuff.
Old 06-12-2017, 01:21 AM
  #1545
Lapis
Lapis's Avatar
Ugliest current 911 variant. Bears a striking resemblance to....
Quick Reply: 991 GT2RS
