79 5 spd Save
Old 11-29-2016, 10:29 PM
  #211
AirtekHVAC
AirtekHVAC's Avatar
Guy, that is ugly, you should be ashamed......but dont worry, I will be over there tomorrow to take it off your hands and save you from its disgustingness
*sigh*
just kidding....its awesome, and I want it. Great work!
Old 11-30-2016, 06:49 AM
  #212
Guy
Guy's Avatar
*sigh*
Hah! I think the real shame may come when you see the rest of the car
Looks positively scary until the hood is opened.
Thanks for the kind words, I look forward to seeing your progress on #30 when the season slows down!
Old 11-30-2016, 06:37 PM
  #213
AirtekHVAC
AirtekHVAC's Avatar
Well, good ol #30 is slightly mothballed until I get the white 82 put back together. I cannot show up at SITM for the 5th year in a row not driving one of my own 928's . But.... I did just buy an axle for her from Mark, So she will get a little lovin'
Old 12-12-2016, 10:44 AM
  #214
Guy
Guy's Avatar
So the engine bay is done and the engine is ready to install. I am awaiting the kids to have college winter break to do the actual install. Decided to keep busy with the details.
Coil is done, using GM corporate blue which is a great match. Thanks to Rob Edwards for the decals
Smog pulley and filter housing freshly powdercoated
Old 12-12-2016, 12:13 PM
  #215
dcocci
dcocci's Avatar
Awesome work. I'm also working on a 79 5 spd and I admire the attention to detail you have. My racecar project is hardly the same haha. Keep up the good work!
Old 12-12-2016, 02:06 PM
  #216
Guy
Guy's Avatar
Thank you! I am getting excited to have the install done.
Old 12-12-2016, 10:21 PM
  #217
Guy
Guy's Avatar
Power steering reservoir. Now where is that polished thumb nut
Old 12-16-2016, 09:11 PM
  #218
Guy
Guy's Avatar
Air pump is done. Not sure which is technically correct, the blue label or the black one. The blue was on the car but the black one was a little nicer so I reaffixed it to the refurbished pump. I have also seen Phillips head 10mm hex bolts used to secure the pulley to the hub but I went with regular bolts as that is what was on my pump originally.
The cast iron pump backing should be painted black. Will be addressing that before install.
Old 12-27-2016, 07:40 AM
  #219
Guy
Guy's Avatar
We installed the engine on the 26th. Never had an easier install. I updated the engine mounts to the later style so the engine sits a tad high until it settles. Now onto to the remaining accessories and clutch. I am shooting for a mid February start up
Old 12-27-2016, 10:47 AM
  #220
VanD
VanD's Avatar
Wow. Nice work.
Old 01-02-2017, 09:48 PM
  #221
Guy
Guy's Avatar
Originally Posted by VanD
Wow. Nice work.
Thanks, Van!
I did the clutch install today, updated to the later ball stud and clutch arm while I was at it. Job went well but I do hate lifting that clutch pack in place. Need to get me a lift one of these days.
Also installed the ground. Amazing what commercial wheel acid will do to clean aluminum and other metals. Before and after shot after one spraying.
It was like new after two more sprays and a little scrub.
Next is the engine accessories and the radiator. Start up by end of month looks like a real possibility!
Old 01-03-2017, 10:47 PM
  #222
AirtekHVAC
AirtekHVAC's Avatar
Keep it up!
Old 02-04-2017, 03:19 PM
  #223
Guy
Guy's Avatar
Well.....
It lIves again! We started it today. Ran good considering I have adjusted nothing. I let it run over a period of 40 minutes. It cleared it throat pretty good. No more smoke now. Starts easily but the idle is way low and can be hard to keep running.
Minor issues so far:
slight slight slight fuel weep at the feed line to the fuel distributer.
oil level sensor is wonky
BUT the best part is that it drives! I was able to turn it around in my driveway and pull it back into garage. Clutch is smooth as silk!!
Now the tune starts. Need to reread my own posts to relearn all that I once knew about CiS.
Great day!!
Old 02-04-2017, 05:58 PM
  #224
sydneyman
sydneyman's Avatar
That is a work of art! Glad to hear its running under its own steam!
Old 02-04-2017, 09:09 PM
  #225
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,707 Likes on 1,310 Posts
Beautiful work, Guy, and congrats on the newfound mobility!
Quick Reply: 79 5 spd Save
