996 Forum 1999-2005
What have you learned since joining Rennlist?
Old 09-22-2016, 10:17 PM
  #106
ejdoherty911
ejdoherty911's Avatar
I learned you can read seven pages of replies to the question "What have you learned?" and learn nothing at all.
ejdoherty911 is offline
Old 09-22-2016, 10:30 PM
  #107
FRUNKenstein
FRUNKenstein's Avatar
Originally Posted by ejdoherty911
870. I learned you can read seven pages of replies to the question "What have you learned?" and learn nothing at all.
FIFY. Let's maintain number integrity, fellas.
FRUNKenstein is offline
Old 09-22-2016, 10:35 PM
  #108
DTMiller
DTMiller's Avatar
871. Whatever
DTMiller is offline
Old 09-22-2016, 10:36 PM
  #109
gnat
gnat's Avatar
999) KC likes the color red. I mean really likes it. Would probably have sex with it if he could. Yes really. THAT much.
gnat is offline
Old 09-22-2016, 10:45 PM
  #110
FRUNKenstein
Hey, BTW, how tf did you two jack legs avoid being PROMINENTLY featured on b3's list?
Old 09-22-2016, 10:49 PM
  #111
gnat
gnat's Avatar
No idea. Just confirms he's an idiot I guess
gnat is offline
Old 09-22-2016, 10:56 PM
  #112
DTMiller
DTMiller's Avatar
696969. I'm forgettable. It's a talent I have. Ask no one.
DTMiller is offline
Old 09-22-2016, 10:58 PM
  #113
FRUNKenstein
Well then, Mr. Talent, my avatar's getting a little stale.
Old 09-22-2016, 11:35 PM
  #114
DTMiller
DTMiller's Avatar
I'm on it!
DTMiller is offline
Old 09-23-2016, 01:07 AM
  #115
FRUNKenstein
Old 09-23-2016, 02:15 AM
  #116
Cuda911
Race Director
Cuda911's Avatar
Originally Posted by Jason 996
When perspective 996 owners are considering ownership:
70% of the 996 owners (without a fix/solution) or IMS failure issues tells them that IMS failure is relatively not as big of an issue when considering 10% failure.
10% of the 996 owners with IMS failure tells them to be careful and usually their story of the money issues involved.
The other 20% that handled the problem with a preventive solution are laughing there a## off at both of them knowing that the 70% are standing in the same line the 10% were in, they just haven't been let into the club yet!
OK, I drew up this simple IMSB analysis decision tree a couple years ago, but we have enough newbies that I think it's worth reposting.
Simply start at upper right "Sage" = Jake, and follow the logical pathway to lower left "Increased Physical Durability." Note that most pathways also lead through the most-important "WTF" stage.
Cuda911 is offline
Old 09-23-2016, 02:34 AM
  #117
Cuda911
Race Director
Cuda911's Avatar
Now, if we take the output, and run it through a simple "before" and "after" IMSB replacement analysis, we can arrive at a significantly enhanced result:
Cuda911 is offline
Old 09-23-2016, 02:37 AM
  #118
Cuda911
Race Director
Cuda911's Avatar
Alternatively, we can use a simple kinetic analysis IMSB decision tree:
Cuda911 is offline
Old 09-23-2016, 02:50 AM
  #119
Cuda911
Race Director
Cuda911's Avatar
84. Hopefully learned ya something.
Should be a sticky.
Cuda911 is offline
Old 09-23-2016, 08:32 AM
  #120
Esfoad
Esfoad's Avatar
Hi All. I'm a recent owner of a 2002 Carrera Cabrio, silver on blue. Car has only 36000 miles on and so far I love it. I have been lurking here for a month since I purchased the car and learned a lot about my car. For example, I now know about the IML failure and it's my plan to address this when I put the car away this winter. Not sure how yet but there's a fix that doesn't require engine removal and replaces the ball bearing shaft with a smooth bearing and an oil line for lubrication. Might go this route. I also replaced the factory radio with a Pioneer one that has Nav, Bluetooth, Apple Car Play and sounds great. I didn't put a sub since there is no really good place to put one. I also fixed the driver's window not dropping that 1/4" when opening the door thanks to this forum and I replaced the worn shifter **** with one from Renn, the satin finish ball one. Loving that too! I hope to be a contributing member though I typically post only from time to time. This is a really active forum so I will be watching.
Esfoad is offline
Quick Reply: What have you learned since joining Rennlist?
