Steering Wheel Upgrade
Old 07-31-2016, 10:34 AM
Chaos
Chaos's Avatar
Default Steering Wheel Upgrade
Is there a preferred upgrade over stock?
Thank you.
Old 07-31-2016, 12:08 PM
77tony
77tony's Avatar
Porsche 930, RS, and Club Sport wheels seem to be the more popular choices and what I'm looking for. IIRC, Roger carries them all. T
Old 07-31-2016, 12:54 PM
hlee96
hlee96's Avatar
Here's how it looks inside the cabin. Feels great with better and thicker grip to the rim.
Old 08-04-2016, 02:37 PM
928gt
928gt's Avatar
There are some recent suggestions here:
https://rennlist.com/forums/928-foru...ing-wheel.html
Old 08-04-2016, 02:49 PM
77tony
77tony's Avatar
Hoi, Is the emblem embedded in the horn pad ? If so, what wheel is that re: 968 Club Sport or ? Part # of wheel and hub please. TIA T
Old 08-04-2016, 11:44 PM
Michael Benno
Michael Benno's Avatar
Here is what a Momo Millennium looks like. You can get them from Pelican parts and other sources. I really like the size (350mm) and the little grooves and nubs for daily driving.
Old 08-05-2016, 01:16 AM
hlee96
hlee96's Avatar
Sorry Tony, but I can't seem to find the same product from this seller that I bought from last year. It came as a set, hub and steering wheel. The description stated that it was "GENUINE PORSCHE 928 / GT / GTS / S / S4 CLUB SPORT STEERING WHEEL BRAND NEW"
The emblem is embedded in the horn pad.
http://www.ebay.com/usr/ambiguous_stuff
-hoi
Old 08-05-2016, 01:07 PM
77tony
77tony's Avatar
-hoi
Hoi, Could not find anything on that link Did find a 968 Club Sport in the UK http://www.porscheshop.co.uk/acatalo...sche_momo.html
with crest, no seam on bottom spoke in preferred 365mm sizing. T
Old 08-05-2016, 01:12 PM
GeorgeM
GeorgeM's Avatar
I have a Momo Race in the classifieds if you're interested. It's a great wheel.
Old 08-05-2016, 04:17 PM
hlee96
hlee96's Avatar
Hoi, Could not find anything on that link Did find a 968 Club Sport in the UK with crest, no seam on bottom spoke in preferred 365mm sizing. T
Tony, After I purchased the steering wheel from ebay seller, I found this from Suncoast Porsche. Looks the same except for the center crest. Leather seams and all match my wheel. I remember the seller's description stating that it came from the same "Porsche steering provider" A--- company (I forgot what the name was, but it starts with A).
http://www.suncoastparts.com/product/SKU928SSBLA.html
Old 08-05-2016, 05:56 PM
77tony
77tony's Avatar
Hoi, That's looks like the one Roger carries. I want to go with the seamless type and a little bigger at 365mm. Thanks again. T
Old 08-05-2016, 05:59 PM
mdkelly1
mdkelly1's Avatar
You can get the 928 Sport Steering wheel from Roger as well.
Old 08-19-2016, 10:12 PM
Crumpler
Crumpler's Avatar
In an homage to GeorgeM, here's what his wheel looks like in my car:
I ended up getting a momo hub with the JWest eccentric adapter to put the wheel up and back slightly.
I came across an old red momo horn button... I figured it would look like a toy car with that installed in the center so I fabbed a black vinyl cover for it.
After that i was pleased, but I may have a one off made with the 928 embossed logo on it.
Old 08-19-2016, 10:35 PM
928gt
928gt's Avatar
That looks nice, although I am unsure about something... wouldn't the eccentric adapter make the entire steering wheel move around? When you turn the steering wheel, say, 90 degres to one side, it doesn't simply rotate about its center but around a point below the physical center, making the entire steering wheel shift position and wobble... in the case of the 90 degree turn. the center would drop down and move to the side by the amount of the offset (like an inch or whatever the distance between the hub and steering wheel bolts is) and the sterring wheel rim would furthermore completely change the angle so that one side would now be noticeably closer than the other forcing you to extend one arm even more while you elbow yourself with the other? I'd also think that would make it a little less stable because any weight placed on it (like you resting your hands while holding it) would tend to push it down on either side as it now rests on the end of a lever. Or am I missing something?
On a different note - where did you get that aluminum shifter gate? Looks very interesting...
Old 08-19-2016, 11:12 PM
Crumpler
Crumpler's Avatar
Carl used to sell the shift gates, I don't think they are available any more -- not that many of us, apparently, were ready for the look, shall we say.
I always loved the Italian look, soooo it works well for me, nice tight solid shift pattern too.
In terms of the eccentric, let's hope it doesn't work the way you describe, lol. I will let you know when I take it out tomorrow...
You are still turning the hub, same as before I would think. Just a hub 12mm longer and wheel set 18mm higher to see the gauges better, but for me I can also have more leg room.
http://www.jwesteng.com/shop/home/15-steering-eccentric-adapter.html
Quick Reply: Steering Wheel Upgrade
