Old 05-27-2016, 03:17 AM
  #7441
2002M3Drew
2002M3Drew's Avatar
Replaced my hatch shocks, and fixed my sunroof by checking the relay and plugging it back in!
Old 05-27-2016, 10:24 AM
  #7442
V2Rocket
V2Rocket's Avatar
advanced cam gear 2 degrees for the purpose of doing dyno testing comparable to my last test with Rogue Tune + 2 degrees.
found an oil leak, looks like the front cam seal...will get to that.
Old 05-27-2016, 10:27 AM
  #7443
SloMo228
SloMo228's Avatar
I helped my dad change the transaxle oil in his 986 yesterday, definitely made me appreciate the simplicity of my 944! With all of the removing braces and covers and such, it took us close to 3 hours to drain and fill the transaxle and get the car buttoned back up. O_o
Old 05-27-2016, 11:55 PM
  #7444
2002M3Drew
2002M3Drew's Avatar
Stretched new black shifter cover over an OEM **** late last night, after much work getting everything to tuck in under the shift pattern disc. Installed the new boot today.
Also recharged the AC with a can of 134A.
Minor glass hatch repair with some sealant at the top of the passenger side of the glass.
Fixed a rattle-y center horn pad by tightening the brass bolts - and my horn started working properly as well! Two birds, same stone!
She's going to get a good bath and vacuum tomorrow.
Old 05-30-2016, 07:46 AM
  #7445
curtisr
curtisr's Avatar
Discovered that a universal momo steering wheel adapter is universal if I weld it on. @#$%
Old 05-30-2016, 08:54 PM
  #7446
J1720
J1720's Avatar
/\ that's hard core
Old 05-31-2016, 12:59 AM
  #7447
ideola
Former Vendor
ideola's Avatar
DProd engine finally in situ.
Readers digest of this build: 2.1 Liter long-rod high compression stroker. Stroke increased by 3mm (via offset grinding the rod journals), rod length increased by 6mm, compression ratio set to 11.0:1, all using readily available, affordable off-the-shelf components. Saves over $1000 when compared with my custom 2.2L stroker setup where everything was custom. Big valve 931 head (44mm intake, 37mm exhaust), lightweight solid lifters, Integral Stage 1 (with a Stage 3 in reserve if I ever want to do a big track). Dual Weber DCOE45 carbs, MSDS 4-2-1 ceramic coated exhaust header, cat delete, custom stainless cat-back exhaust. Coil overs on all four corners for easily adjustable ride height. Will eventually replace stock ignition with MegaJoltLiteJr EDIS wasted spark programmable ignition.
Old 06-01-2016, 01:27 AM
  #7448
No Lag
No Lag's Avatar
Cruise control modual: Soldered some cracked joints. See them....me either. I had to get a magnifying glass to inspect all of them!
Test drive tomorrow to see if it fixed the inop problem.
Old 06-01-2016, 01:35 AM
  #7449
V2Rocket
V2Rocket's Avatar
drove it, did some tuning...put some gas in it.
Old 06-01-2016, 01:16 PM
  #7450
pdxfj
pdxfj's Avatar
Over the three day weekend I did my first autocross. Quite fun and frustrating at the same time. Learning the course took four DNF's to figure it out. Only went one day and it was cut short after a vette spun out and crashed into a jersey barrier. Driver Ok, car needs some help..
Managed to get my hands on a few cans of R12 and charged the system. Was not working but still had pressure. Took one can to get it blowing cold again. Been a long time since I've been in a car that still uses R12. Amazing how much colder it is than a newer vehicle with R134a.
Temped to take a stab at the Cruse control module. Supposed to be really hot this weekend. Might be a good weekend to sit in the basement with a soldering iron and a cold beer.
Old 06-01-2016, 01:52 PM
  #7451
ideola
Former Vendor
ideola's Avatar
Progress on the 88 924S SE performance build:
Top-end together now:
Underdrive pulleys, lightweight balanced drive pulleys, and adjustable cam sprocket set to +4°:
Custom mounted 951 oil cooler, lines, and filter console to eliminate the troublesome water-air setup on the original 8v motor:
Solid motor mounts:
AC delete bracket:
Old 06-01-2016, 01:59 PM
  #7452
thirdgenbird
thirdgenbird's Avatar
Dan,
Is the a thread or blog for that car? I think we were/are headed down similar paths.
I've been thinking about a 951 axle and GPS speedometer. This was the car you did that to correct?
  #7453
V2Rocket
V2Rocket's Avatar
youll notice a big difference in coolant temp!
Solid motor mounts:
ouch
AC delete bracket:
A Dimi special...
Old 06-01-2016, 02:41 PM
  #7454
ideola
Former Vendor
ideola's Avatar
Originally Posted by thirdgenbird
Dan,
Here y'go!
http://924board.org/viewtopic.php?t=39806
No, I think you're thinking of my 931 Club Sport build. I used a GPS speedo in that one because I installed 86 951 brembo package and didn't want to mess around with drilling the spindle.
I set up a page on 924board with a post for every car I've ever purchased, and cross-links to build threads:
Chronology
Old 06-01-2016, 03:22 PM
  #7455
Northern_aqs
Northern_aqs's Avatar
Ordered VEMS for the turbo. Very excited to simplify the tuning process and eliminate the chips of unknown origin.
