Scissor liftt
Old 12-28-2010, 12:29 PM
  #31
Imo000
Captain Obvious
Super User
Imo000's Avatar
Originally Posted by theiceman
There is an engineering issue with lowering it. On the floor the force is distibuted radially out fromt the stand point across the entire floor . If you were to dig down 6 inches redo the concrete and put the lift in you are distributing the weight over a much samller area, basically the size of the pit you dug. If you are on the gravel bed underneath you might be okay but if there was any settling underneath it might go through the floor.
i might do this but would need to consult a civil or construction engineer.
You are right, it's a bad idea to cut the floor. But if you do, have to drill the side of the old slab and pin it to the new one but even that is not an ideal setup. Best is not to touch the floor, most garage floors are pretty thin to begin with.
Old 01-08-2011, 11:08 AM
  #32
stacheman
stacheman's Avatar
Originally Posted by FFaust
Group buy?
I'm in for a group buy!!!!
Old 01-08-2011, 11:27 AM
  #33
The Stig
The Stig's Avatar
I'm in for a group buy as well. But $1,700 CAD is too steep for me. Mid rise scissor lifts can be had for close to $1,000 in the US. I'd be happy to drive to Buffalo and pick one up to save a few hundred dollars.
Old 01-08-2011, 03:06 PM
  #34
FFaust
FFaust's Avatar
Well I'm out. Just picked up crawler and a set of these: https://rennlist.com/forums/997-gt2-...ml#post8193714
Next step will be build a bigger/higher garage, and get a proper lift
Old 01-08-2011, 04:03 PM
  #35
The Stig
The Stig's Avatar
They look good. But what did the come to all-in? $900? Hmm. Cheaper than a mid-rise, but not buy much if you shop in the US. Really clever design though. I'm impressed, but on the fence
Old 01-08-2011, 06:40 PM
  #36
FFaust
FFaust's Avatar
Cost me less, but I bought some "used" pre-production units. Not cheap by any stretch but yes, quite clever, but more importantly, safe and easy to use.
Old 01-08-2011, 07:16 PM
  #37
Mark Lue
Mark Lue's Avatar
Those are just fancy / expensive jackstands, I'm getting to the age where crawling and laying under my car isn't doing it for me... . I've seen Jim's and that the way to go.
Old 01-09-2011, 11:13 PM
  #38
Imo000
Captain Obvious
Super User
Imo000's Avatar
Have a look at this: http://liftbars.com/ They are for 928s but if there is enough demand, Ken will make it for other models too. I think they are a better alternative to the jack lift ones.
Old 01-10-2011, 02:03 AM
  #39
FFaust
FFaust's Avatar
Wow, I'm impressed
Old 01-10-2011, 10:25 AM
  #40
Ronan
Ronan's Avatar
Make sure you don't do this.........http://www.youtube.com/watch?v=30InB...layer_embedded
Old 01-10-2011, 11:21 AM
  #41
JimV8
JimV8's Avatar
That scares me.
Old 01-10-2011, 12:49 PM
  #42
IMGT3
Former Vendor
IMGT3's Avatar
Default jackpoint jack stands
Hi, I am Chuck of IMGT3 performance. We're the distributor for this product and I'd like to point you to a link that demonstrates the functionality of the Jack stand.
http://www.youtube.com/watch?v=D0Sbl...er_profilepage
this is a direct link to our youtube video of an M3 being lifted onto the stand. The significance of this product and why it's so good and different from other stands is first, you put the jack stand in a factory Jack point while using a point to lift the car. Second, the cap connects in such a way with a factory lift point that it cannot slip once set in place. the base understand his oversized giving a great foundation And very good ground clearance. The stability of the car when lifted up on two or four of these jack stands is the best I have ever seen. My wife is even comfortable when I'm under the car, if you can believe that!
These are sold in pairs, and range from $289 - $369, less our member discount. If you have any questions please been free to PM me.
Chuck
www.imgt3performance.com
Old 01-10-2011, 03:22 PM
  #43
theiceman
Team Owner
theiceman's Avatar
Received 1,140 Likes on 814 Posts
I must admit that is pretty cool , as it is a frustrating thing for me that on my A6 the only place to jack the car is where the jack stands should go . But i could put up with a lot of frustartion for over 300 bills US
Old 01-10-2011, 03:37 PM
  #44
Imo000
Captain Obvious
Super User
Imo000's Avatar
Originally Posted by jim 7
That scares me.
In what way?
Old 01-10-2011, 04:14 PM
  #45
MY86Carrera
MY86Carrera's Avatar
Ice... just get a scissor lift - your back will thank you for it.
I had my back surgery almost 3 years ago - I'm as good as I'm ever going to get - 2 post hoist installed last July = best tool in the tool box next to very large compressor and air tools. Mine was 2k installed.
Brad
Quick Reply: Scissor liftt
