Jackpoint Jackstands ???
Have you tested to failure? How heavy until the legs start to spread - across the opening?
Group buy... to increase visibility at tracks around North America.
just by eyeballing it, the jack arm looks like it would be a tight fit at best
I have not measured yet but thought I would ask before I got inspired :-)
wheel width is about 11 i am told... called my wife had her measure it
jack pad - fine
jack arm she says is 6 inches wide - I will be able to measure it myself later this week
let me know what you find and if inconclusive I will take measurement pics and post etc
Also, I can do the math so I am posting these here for the benefit of the manufacturer and distributor and any other RLers that were curious about using this jack with these jack stands.
so... overall picture of the jack
Per the instructions on the IMGT3 website
http://www.imgt3performance.com/User...structions.pdf
The jack plate must be 3-5 inches in diameter
here is a pic of the jack plate base - which will work... I neglected to measure the actual jack plate pad that you can see in the picture above, but I think it is alright.
The jack base should be 11.75 inches or less - so we are good
The jack lift arm should be 5.5 inches or less -- we are not good
as you can see the jack arm is the limiting factor 5.625" when the instructions detail 5.5 or less...
It is very close -- close enough that a grind in the right spot might "make it work" but I am not too keen on grinding the jack stands or the jack at this point.
So -- is it close enough that it will work without modification?
In any event, I hope this has been helpful.
