Any Rennlisters from New Zealand?
Old 02-24-2014, 03:33 PM
  #10291
O2GO
O2GO's Avatar
Originally Posted by Maxem
Thats me Doug, thats what I'm thinking of. I think that is Rob Dickenson's car, the guy who owns Singer. He's had it for ages so it isn't a singer but it's that car that got him thinking. I believe it's a T.
Ahhh, that explains it. I like the hard out rear air grill. It looks tougher/meaner than a Singer to me although not many photos there yo do it justice. Looking forward to your build. You should start a thread for your build
Old 02-24-2014, 04:22 PM
  #10292
CS Mende
CS Mende's Avatar
Originally Posted by John McM
No spoiler to switch on mine and have never used the 4wd button. Only buttons I actually use are the emergency switch and the alarm off one.
What I was planing to use, plus the 993 regular rocker switches for the wing & rear locker.
http://www.rennline.com/Rennline-Rad...oductinfo/I21/
Old 02-24-2014, 04:29 PM
  #10293
floatingkiwi
floatingkiwi's Avatar
Hey Dave what are you building? I must have missed a few posts...
Old 02-24-2014, 04:49 PM
  #10294
John McM
John McM's Avatar
Originally Posted by CS Mende
What I was planing to use, plus the 993 regular rocker switches for the wing & rear locker. http://www.rennline.com/Rennline-Rad...oductinfo/I21/
Looks very clean. I can see the next year being mostly interior tweaks.
Old 02-24-2014, 05:14 PM
  #10295
PHG
PHG's Avatar
Hey John
What pressure were you running those tyres at. They Nitro filled?
Hoping for Uncles next week for maiden voyage
Old 02-24-2014, 05:18 PM
  #10296
John McM
John McM's Avatar
Originally Posted by PHG
Hey John What pressure were you running those tyres at. They Nitro filled? Hoping for Uncles next week for maiden voyage
I think I ran them at 32 hot, the same as the 17" versions. Garden variety air.
I'll ask Chris B what he runs his 996TT track tyres at. Matt G might be even more up to date as he runs Z221s.
I'm not sure what you've run to date, but if you've never had track tyres you are in for a treat. These stick like doodads to a blanket.
Old 02-24-2014, 05:34 PM
  #10297
mjg
mjg's Avatar
Hey John
I'd try 32 front/36 rear hot.
Old 02-24-2014, 06:10 PM
  #10298
ChrisB_NZ
ChrisB_NZ's Avatar
I run 32 all round hot on my Dunlops, but haven't run Z221's on the 996tt so would go with Matt's experience.
Old 02-24-2014, 06:12 PM
  #10299
ChrisB_NZ
ChrisB_NZ's Avatar
Originally Posted by kiwi 911
I wonder if there is a chance to do a another HD day before SITT. Would be interesting to see time difference with suspension sorted??
I'm running in the Prestige group on Wednesday 12 March as a final chance to test anything before the SITT.
Old 02-24-2014, 06:21 PM
  #10300
mjg
mjg's Avatar
You can certainly run 32 rear, I did that for a while but started experimenting with 36 to see if it'd help with heat/wear.
Old 02-24-2014, 07:08 PM
  #10301
PHG
PHG's Avatar
Thanks Matt,John and Chris
given my first try at these, what cold start temp you recommend
Old 02-24-2014, 07:19 PM
  #10302
John McM
John McM's Avatar
Thanks Matt,John and Chris given my first try at these, what cold start temp you recommend
I can only talk to the 17". I used to reduce my pressures to 25 rear and 27 front, when at the Track as soon as I arrived. That brings them up to 32 hot.
As I have become faster I've had to reduce the fronts to 26.
Old 02-24-2014, 07:23 PM
  #10303
kiwi 911
kiwi 911's Avatar
Return of the Wild West:
Uncles....
The sweet scent of rubber and brakes is in the wind...
When: Wednesday 5th March - **Twilight** Laps Start @ 4.30pm and will run through to 07.00pm
Sign in from 4.00pm THE SOONER WE ARE DONE THE SOONER WE ARE ON THE TRACK!!
If track gates are closed Sign in will be at ticket office in main carpark then gates will open @ 4.30pm
What to Bring: $65 Per Driver - Cash or Cheque Sorry No Eftpos/Credit Facilities Available
Helmets are Compulsory - Motorbike / Motor Cross Helmets are OK
Where: Hampton Downs Motor Sport Park - Hampton Downs Road Off SH 1 Waikato Expressway - Centre Track
Old 02-24-2014, 07:34 PM
  #10304
ChrisB_NZ
ChrisB_NZ's Avatar
I typically start around 26 all round and then adjust them all to 32 when I come in hot from the first session.
Old 02-24-2014, 09:10 PM
  #10305
Macca
Macca's Avatar
Here is one of my favourite 993 interiors (with backdate 964 lower dash) Doug which I think will strike a cord with you. You will need to imagine it in black carpet. Very similar to the ones you posted, nice mono chrome look with drilled billet alloy anodised black features....all parts can be purchased off the shelf and not an overly expensive conversion .
Not much I would personally add to this other than the ubiquitous Heigo half cage and these cool drilled black exterior door handles which match the inside door furniture, along with the WEVO anodised shifter with Pelican drilled shifter head for effect...
Quick Reply: Any Rennlisters from New Zealand?
