HANS Feedback from the manufacturer
#32
Oddly enough, I experienced last year the sliding tethers "hanging-up" in my DSR (at Gingerman, transitioning through 7-8-9 from the RH to the LH turn)... rather a bit disconcerting, and still not entirely sure if I've cured it - I'm still not entirely sure what was happening...
#33
Hahaha! How, indeed....
Not sure what a "truck slider" is...I will take it as a badge of honor...but it's funny to see someone spew out pejoratives here in multiple threads...most of which actually describe that someone to a tee.
I have never had any issue with the "standard" tethers on track. Ever. Contrary to claims made here, they have never nor will ever hinder anyone's ability to properly scan peripherally and get visibility of all vehicles nearby (obviously, a blind spot is still a blind spot). But they are somewhat limiting in tight paddock spaces.
#34
I'll admit you guys have forgotten more race knowledge than I'll ever know but I've been reading Rennlist and the Racing forum here for a long time now and these threads just don't belong.
I've seen some bad threads on Rennlist but these really take the cake.
#35
Administrator - "Tyson"
I don't have a problem with Mark's posts or comments and if I did I would simply ignore them.
Try a little restraint.............in 3rd grade I was taught to turn the other cheek. Funny how simple life lessons become so complicated for some adults.
Nobody is forcing you to open these threads, much less post something.
#36
I'm not sure what is worse, some of us bantering with Kibort or you bumping up his thread to complain about it.
It takes at least two to tango...........
Pot. Kettle. Black.........
Scott
#37
I still contend as many others here have, that the ring is not ok and is a seriously bad idea. And it's less of an Hans device issue and more of a belt issue. Here's why:
1. The belts are designed to lay flat. Anything that pinches them will localize stress in the belt, like tearing a peice of paper, if you pull flat on the end of a peice of paper it will actually take a pretty big load, pull at a diagonal and it rips right in two. That's why you have to do all the double wraps and the belt mfgrs are so picky about keeping them flat and not pinched. If it weren't for this you could just cross the belts left to right behind the seat and get the angle, but you can't because the wrap wouldn't be right.
2. The ring pinches the belts together to keep them on your shoulders, which are tight right to the point where you hit something. That ring will deform and open up like an oval at best, creating a bunch of slack in the belts even before they stretch, or worse cause localized stress on the belt(not the device) causing the potential for a failure (tear). So just like the patch issue there is a right and a wrong way, one that meets the recommendations of the people that designed the systems, the belts in this case, to maximize the probability of surviving a bad crash and injury so you don't have to type with a stick in your mouth.
Why compromise if you don't have to? Why start out with a less than perfect situation to start with? And I'm not talking about the old Hans, I'm talking about the way you're trying to fix the symptom not the underlying problem with the ring.
It's like those shows that show people crashing on skateboards and BMX bikes; even before the actual crash you cringe cause you already know that the kids face is going to plant it in the concrete or the guys leg is goi g to fold in places and directions it's not supposed to...you kinda know what's wrong and what's coming without a lot of analysis, something is just not right...
When guys that love to bait you into a moe like three stooges slap attack stop and voice genuine concern, I think it's time to stop and reconsider.
Anyway, no need to counter post this I can't be convinced otherwise and there's no "winning" here just think you should take your setup to a good shop and spend $20 to have it set up for you.
Be safe out there...
#38
Mr. Excitement
When did the fixed tethers become unsafe? I have used my Hans with both and while I like the sliders better most often in the paddock found little issue with ether. I also seem to recall that there was some question of the safety of the sliders when they came out. I also recall that they are about the same with regards to safety acording to Hans.
#39
Its simply due to an ego the size of the stadium he was in when he competed in American Gladiators.
#40
I don't think you have to wonder, people intimately familiar with fire and protecting us all from fire know it is. The only debate is how lucky do you feel in avoiding fire all together.
the ring is a very weak spring that has no effect on the pinching the belts when attached. it only narrows the angle by small amout again, when removed (we did this) there is no tension change on the belts. however it did make a difference on how well the belts stay on the shoulder guide legs of the HANS.
#41
#42
go back to truck sliding and have fun in your quest for self promotion.
again, small man complex is running rampant within you!
Feel better every post dont you!
#43
you guys are totally hilarious. when i showed i had the old style tethers, everyone said to get with it and replace them, now that i confirm that this is true, you go back to say the original design is fine. classic! are you guys for real??? look, they bug the heck out of me and I cant see with thm connected AT SPEED, in a race! so, if HANS decided to change them out on ALL their devices , maybe it was an idea that was decided as being better.
But, im sure they should have consulted with you first!
unbelievalble! truely!
carry on . fire off a few more personal attacks to make yourself feel better about YOU!
#44
now YOU are advocating something I feel is very dangerous. vision is paramount in racing, but remember , you dont race, and when you do, you usually are in the traps or pointing backward. blaming those around you for your misfortune. there is never a problem until there is a problem!
by the way, i found the fixed tethers are fin in the paddock going 5mph. i can use mirrors and see just fine. at speed, truely is the issue. again, if i knew anyone was racing with them, i would use that knowldge as a part of a strategy to beat them
(here is proof of this point to help those that can be helped. put hans on and fixed straps. have someone stand at your blind spot (normal mirror blind spot). then walk 4 feet forward. you wont be able to see them because you cant move your head to see them as you would if you were racing. (at speed)
hey, if you are find with this decreased vision, knock yourself out.
again, just bringing it up to help.
#45
So it doesn't bother me in the least that someone is bumping up his threads.
I cannot say the same for you, the others I quoted in that post or a few more that cannot resist the gang pile
On top of that we have those who really want attention by reporting every single little comment that gets their panties in a wad.
Threads like this are like babysitting my sisters wild kids, and Kibort is their Great Dane running around dragging a bicycle he was tied to.
I just find it rather humorous how many of you bump up a thread just to complain about the thread existing.
I'm sure some other moderator will swoop down and stop all the fun any minute now.
Until then, carry on.....where is my popcorn?
