Danica's Violent Crash Yesterday At Daytona....
#47
Mr. Excitement
That's why right side nets are still recommended even with halo seats. I've had two big shunts in fully supported ultrashield roadrace superseats similar to the butler or laJoie full containment seats. I credit them with me walking away without even being dazzed. I cringe at people using aluminum seats supported only at the base. They fold like pretzels. If you don't go all the way at leaset us a currently dated FIA seat.
The fire bottle is mounted pass side foot well near the center tunnel to protect it and the activation cable. Safety pin is easy to see and remove while strapped in. main battery disconect is also easy to pull and reset from drivers seat.
Looks like Danica did things right when things went wrong. I bet that same hit 20 years ago would have come out far worse considering the safety systemsused in the cars and on the tracks of the times.
#49
Those inside wall hits look harder perhaps since we get to wait while the car takes its time getting there. I wonder if they are harder hits than to he outside wall where you are maybe? going faster but are right there net to it. It seems like maybe they should double up the SAFER barrier on the inside walls.
#50
FWIW, Danica spoke at the National Press Club this week. I happened to catch it on CSPAN Friday night.
It was a great talk and she handled herself well. Good insight into the industry and her development path, and made it clear that she is far more self-aware and realistic than she may appear at times [eg in the GoDaddy commercials]. I always thought she was a lightweight, but have to re-calibrate after this.
#51
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
In the open wheel design criteria, there is to be ample room designed into the monocoque for a driver to be able to pull his/her knees up to pull feet from the pedals. This area is around the damper area, just below.
Like many have said, trained to do one thing, and actually doing it are often times two different things.
#53
No need to take off work. It looks like the weather won't permit a start until late afternoon/early evening. It may even get pushed back until tomorrow.
#56
King of Cool
I think (especially for Ovals) they should.
#57
If you watch it regularly (I do) different drivers have different type of seats and amount of containment.
#58
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
They can be done for about 200 bucks at home with a helper. The good seat fitters charge about 1500 for all the work start to finish including the materials. I've done/sold about 50 kits/seats in the last couple years. It can be done in the composite seats like recaro and racetech too. The key is buying a seat 3 sizes to big and then making the insert.
