ASK THE COACH
#1036
Thanks to both of you I guess I was heading the wrong direction in my approach. I am adding a data system in a month or so. Thanks. I just though real time feedback would be helpful.
#1037
Basic Site Sponsor
Basic Site Sponsor
Received 3,299 Likes
The only reference I'd recommend while on-track is rpm at corner exit. That is generally a better indication of performance, and totally safe.
Brake with identical pressure as you have been doing, but begin braking 10' later. As long as you release the brake and turn-in at the same point, you will carry more speed at entry.
On the raising vMin exercise, my experience is that most drivers (and nearly ALL club-level and track day drivers) do not and, without significant practice on executing JUST that fundamental skill, CAN NOT "brake with identical pressure" throughout the entire braking zone, even though we all know that that is the ideal.
The few people I see and work with who brake properly, along with others that modulate the brakes to "make the slowing fit the distance they feel they need to slow" just reach the proper turn-in speed well before it's time to turn in...
You need data to figure this out. Once you do have it, it's not hard to look at one or two measures to identify what you are doing and take steps to fix it.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#1038
...my experience is that most drivers (and nearly ALL club-level and track day drivers) do not and, without significant practice on executing JUST that fundamental skill, CAN NOT "brake with identical pressure" throughout the entire braking zone, even though we all know that that is the ideal.
Scott
#1039
Basic Site Sponsor
Basic Site Sponsor
Adam was talking about the approach to the corner. So am I.
To reduce speed to the point where you can blend the end of braking into cornering, which is what you are doing when you trail brake (into every corner?), you need to brake in such a way to initially "front load" the deceleration measure, but then keep it up before turning the wheel. THEN, you can let off, as you do.
Most folks don't do that.
#1040
Rennlist Hoonigan
which cost no drachmas
I think you need to re-read Peter's comment. Doesn't matter if you trailbrake or not, you need to time your brake application right, with the right amount of pressure, in the right spot, at the right time, down to the correct speed (which won't change).
#1041
Former Vendor
#1042
Peter,
Oh, I get it. You mean braking with identical pressure each time in the same braking zone. Not identical pressure throughout the braking zone. That wasn't clear to me when I read your post.
Scott
Scott
#1043
Basic Site Sponsor
Basic Site Sponsor
#1044
OK guys, I've looked through this post and couldn't find anything on it, so if this is a repeat question I apologize for repetition. But, here's one I could use some help on.
I chase very well and run my best overall laps while trying to reel somebody in. I'm not as comfortable leading and can be susceptible to pressure from behind. Any tips on how to change my mental framework?
#1045
Is this a question for a DE format or actual wheel to wheel racing? There are different distractions in each situation that you may need to consider. Following is always easier unless your the middle car in a sprint race and all three of you are equal in pace. DE environment is giving you cues and forcing you look to forward and into the turns a bit more. Following also has you turning in a bit softer and earlier as you are able to observe the car in front of you. If your in a DE and traffic behind you has your concentration a bit off then more seat time is required. The subconscious skills of car balance need to be on autopilot in a race situation (and top level DE groups), but in a DE your in control of the car behind you until your hand giving a point by so use this rule to help gauge proximity of the traffic.
#1046
Thanks Bob and really focused on wheel to wheel. The brain wants to focus on keeping the competition back there instead of getting the most out of my lap. I get the defensive line thing but really feel I've got a mental hurdle to conquer here. Seem to make more mistakes when out in front.
When chasing I feel very comfortable with driving my line and getting the most out of what my car can do.
#1047
If your racing in PCA and your qualifying well in your class then your likely just dealing with the similar pace of close competition. If your a bit back and having lower class racers in your mirrors then the issue is getting the most out of corner entry so defending becomes less of an issue. There is a certain racing group that I have attended sprint races with and they don't run split starts within a large field. The grid is set by pace only which is a big mistake. You have 500whp cars running a similar time to say a 250whp Boxster. They are constantly tripping on each other when the higher hp car pulls on the straight only to slow on corner entry. The lower hp cars constantly attempts passes in low percentage areas. Both cars are impaired and frustrated. I cannot remember one clean race. All of them have had a double yellow from car contact. So managing traffic can be problematic. Following is always easier and sometimes a smart race tactic in wearing down a competitor. If you need to get more comfortable on what the mirrors are telling you then work with a racer in practice events and have them drive just inside your line for an entire session. Get some feedback on where you are weak and work those areas first.
#1048
Thanks Bob and maybe that's the real answer "use makes master". I probably just need to experience it more to get the defensive line down into the subconsious area rather than having to think about it.
#1049
In PCA I very seldom if ever run a defensive line (not including using traffic to my advantage of course) unless I don't know/trust the person that is close to me and am afraid of a dive-bomb, and at this point I usually do. It just slows me down and makes matters worse. In other venues it most likely is a necessity..
#1050
Basic Site Sponsor
Basic Site Sponsor
Personally, I think the whole defensive line idea is bulls#!t. The data doesn't support it, good practice doesn't support it, and if you're quick enough, you don't need it. If you need it, you're not driving as well as you should, or you're not "taking your medicine" if you screw up the previous corner...
