ASK THE COACH
#2296
So far we are batting 1000. Right front wheel off you can see the failed grease now and dots on inside of wheel where it was starting to leak. Right front wheel hub replaced. ![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Like I said, appreciate the help in diagnosis. It is a completely different sound (and very vague while driving), and no feel, vs when the bearings "really" start to go.
Hooked up voltmeter to newly charged battery while running. Can watch volts drop, esp after turning on lights. Next up - new alternator.
If my pit crew doesn't need assistance I'll see about configuring the analogs this afternoon.
Looks like I got some race car parts for Valentine's Day...and I guess new wheel hub and alternator.
#2297
Looks like I got some race car parts for Valentine's Day...and I guess new wheel hub and alternator.![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
It's good to hear you confirmed the cause of the noise.
One thing you can do with the analogs, is just enable them on the TM and then observe them on your display. Press and release the gas with the key on (not running) and see if any of them react. Press the brake and see if you see anything. It also may be easy enough to follow the wire.
Chick happy with car parts for Valentine's Day? Surlynkid, that's what we call a keeper.
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
-Mike
#2298
She got 3 sets of front pads, 2 sets of rear pads, another spare set of rotors, spare coil pack, 2 spare axle shafts and both rear knuckles as complete drop in spares. What else could anyone want.
#2300
#2304
Hot wire connection at alternator had broken due to fatigue and age. Removed broken piece, crimped on new one to wire and hooked it back up. Hard to notice as the wire was still sitting where it belonged. Once I disconnected the harness for the swap, the wire flopped out of the way. Easy fix.
#2305
Whelp, more than the bearing. Got about 1/16" of up and down slop on the right rear wheel. Looks to be the inner lower control arm bushing. ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
SL, If you liked my suspension, imagine how much you will like it when it's not broken.
-Mike
-Mike
#2306
While the 48 Hours of Sebring is still relatively fresh in many of your minds, I thought I’d post these two laps from a Chin event I did in January in my 09 Carrera S and seek input and critical comments. Please don’t be shy.
The second lap (shown as lap 4 on the vid) is my PB there by a little over a second. The first (lap 3 on the video) might have been equally as quick or quicker but the Corvette behind me didn’t take my point-by into one so I gave another into 3 which he took. Data shows I lost time in those two corners but the rest of the lap was just as quick as the following one.
This is my first attempt at posting YouTube video so I’m hoping it works!
Thanks in advance,
Mike
Thanks in advance,
Mike
#2307
Dude, those are some pretty tidy laps! Only a couple of small suggestions:
-get all the way to the apex in 13 and you wont be forced quite so wide onto the track out rumbles
-upshift your PDK in Bishops and you'll carry more speed & throttle position and not be on the edge of instability all wound out in RPM
-use a lot more apex curb in 16 and again, you won't be forced onto those nasty track out rumbles
#2309
And why didn't my video post? I put the code between the youtube things like I was supposed to. Mike??? I'm just going to put Mike on retainer for when I have to do anything technical or electrical....
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#2310
BTW, I was expecting a lawnmower race. You know, as described in that issue of Obscure Sports Quarterly along with Midget Tossing. Something like this:
which shows in my preview as a click-able link:
2012 STA-BIL Keeps Gas Fresh Finals Clippings: FXT Class
yet should show up as an embedded youtube clip when posted for real.
At 100 HP, some of those tractors may be faster than a SM
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
-Mike
