Completely stripped down ready for transformation from 944SuperCup to GTS3/GTS4
#61
I brought the car based on a build sheet I was given by the previous owner.
Here's a portion of it showing who built the engine.
1989 Porsche 944 Turbo
Salvage Title 7500
Vin# WPOAA295XKN150411
Aftermarket Performance Upgrades:
• KLB custom welded cage with door bars 2500
• John Milledge Engine; complete rebuild with Porsche oversized pistons and steel sleeves. Dyno Tuned. 18000
• Ohlins 2 way adjustable full coil-over suspension with remote canisters. 7500
• Racers Edge spherical bearings 2200
• Charlie Arms front control arms 1600
Weltmiester strut tower brace
Salvage Title 7500
#62
Here is a picture from Vic at Pauer Tuning, this is his sequential ignition system that we are putting on my car. You will see the coil packs are mounted on the cam tower and the cam position sensor mounted in place of distributor cap.
The 2nd picture is of the layout that Vic uses for the ViPec and individual cylinder knock control system.
Some very cool stuff, thanks Vic
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
#63
Why not remove the door bars? You have the cage for protection?
#64
I had the same discussion with Sloan when I was at his shop Wednesday. We decided to leave them in for now as they offer some support to the door skin. This will help keep the door in good shape in the unlikely event of minor contact.
#65
My guess is that this motor was built a long time ago perhaps before JME used baffling in the sump...just based on the cheap price of the build (relatively)...and/or someone has taken the baffling out subsequently.
#69
The work is all being done at Sloans shop, SSI Performance.
It worked real well and we were able to leave a few things on the car like brake lines etc, plus the cost is a fraction of doing an acid dip.
#70
The rebuild is working out real well as it was also discovered that the oil pick was cracked. So Sloan is going to reinforce that and add a shroud to it when he installs the baffle pan.
Otherwise he said the engine looks in real nice shape, especially as the head had a valve job just before I got it. The leak down test was really good
#71
Cage work was finished today. The nascar door bars were installed and a brace from the cage to each strut tower was also installed.
#72
I can't believe steam cleaning works on that undercoating. you'd have to wire-wheel it or something else.
my BMW is currently being acid-dipped in Texas for $1600. Way easier and cleaner than wire wheeling it. plus if that nasty seam sealer is still in the seams, it'll contaminate the welds.
cage reinforcements look nice. will it be welded to the A and B pillars?
#73
Gary, NASA rules do not allow you to go through the firewall. From the CCR:
15.6.13 Mounting Points
The roll cage shall be mounted to the floor area of the car in six, seven, or eight points. The cage shall not go through the firewall.
#74
I used a heat gun, 5/8" wood chisel, and a drill with wire brush attachments. Was a rough job. Which is why I was impressed with the underside of Gary's tub. None of the primer coat is scratched off.
The residual seam sealer does cause a lot of weld spatter and porosity. Best to get it all out if possible.
#75
Former Vendor
