I signed up with a well known pro. coach...........
Old 07-14-2009, 11:05 PM
  #91
BostonDMD
BostonDMD's Avatar
Carl, I just figured that was the correct set up......and I learned to cope with it.....
Afterall it was a winning car 9 years ago......
Anyway, Dan Jacobs, my new mechanic, will set her right..... then I will have to work on the driver.....
  #92
bauerjab
bauerjab's Avatar
Can torsion bars and sway bars actually get "tired" or is it that
D.J. is going to install much beefier torsion and sway bars.
Old 07-14-2009, 11:14 PM
  #93
BostonDMD
BostonDMD's Avatar
I am not an engineer John, but I would assume that after 15-16 years any metal bars would get "tired"
by the stress and strain induced upon them by a racecar.........
Furthermore, I do believe that the new smart racing torsion and sway bars that D.J. will install will
be beefier and more up to date...... but than again, what do I know?.....I am just a dentist.......
Old 07-14-2009, 11:30 PM
  #94
Gary R.
Gary R.'s Avatar
The torsion bars in there are about 5mm lighter than what we run now, sways are old charlie bars and weak, shocks need rebuild, was almost 0 camber in the rear and half of what is correct in front, and on and on... Going full polybronze, Smart Racing sways, Sanders hollow torsions, monoballs, etc. etc. Should really transform the car.
Old 07-15-2009, 12:46 AM
  #95
paradisenb
paradisenb's Avatar
You will think you bought a new car if all those things are really worn out. Even if they are not all worn out just the upgrade to newer components, installed together like a team will transform your car.
Judging by the video you may want to budget some more $$ for additional items that are going to be found during the in depth inspection.
Old 07-15-2009, 06:16 AM
  #96
bauerjab
bauerjab's Avatar
Paolo,
I had D.J. install that set up on my 87 Carrera. You will like it immediately.
I had to play around with the sway bars to get the car where I liked it.
Other than that, good to go...
Old 07-15-2009, 11:06 PM
  #97
BostonDMD
BostonDMD's Avatar
How do you play around with sway bars?
Is it easy to do at the track?
How do you know when you have reached the ideal setting?
Old 07-15-2009, 11:09 PM
  #98
Gary R.
Gary R.'s Avatar
Sounds like the basis for a Boston 12 pager!
Old 07-15-2009, 11:14 PM
  #99
Veloce Raptor
Veloce Raptor's Avatar
Received 1,609 Likes on 836 Posts
Yes.
Yes.
Yes.
Professional Racing and Driving Coach
Old 07-16-2009, 11:09 AM
  #100
bauerjab
bauerjab's Avatar
Paolo,
From a mechanical standpoint, it's not difficult. A little cramped, but not difficult. Ask D.J. how to do it when you pick up the car.
As for the correct setting, that's going to take some time for you to determine.
Another possibility is for someone else to set up the car - at least to get a baseline. And by set up, I mean taking it on the track and determining a neutral setting.
If you think that's a PIA, be thankful you don't have adjustable dampers.
Just my 02c
Old 07-16-2009, 11:14 AM
  #101
trumperZ06
trumperZ06's Avatar
Good advise.
Have a professional shop go thru the suspension... then get a talented driver to sort the car out at the track.
Old 07-16-2009, 11:32 AM
  #102
Gary R.
Gary R.'s Avatar
Originally Posted by trumperZ06
Good advise.
Paolo MUST be pretty talented to drive that POS as fast as he has!!
Old 07-16-2009, 11:50 AM
  #103
trumperZ06
trumperZ06's Avatar
Recognizing handling issues and setting up a car PROPERLY...
may require a bit more experience than Paolo has.
No one's questioned his talent in driving that ill handling Porsche.
Old 07-16-2009, 11:56 AM
  #104
BostonDMD
BostonDMD's Avatar
Thanks John, will do.......
On a side note, I am proud to say that (under supervision) this past week-end I changed the front brake pads at the track........
So..... you see, there is hope for me to learn a little bit about wrench turning........
Old 07-16-2009, 12:03 PM
  #105
bauerjab
bauerjab's Avatar
Way to go Paolo!!
And by the way, just to be not outdone by you, I have hired my own Factory Trained Ruf Instructor. See my avatar (that is me and my dog). I will ask him if he can help you with your suspension -
John
Quick Reply: I signed up with a well known pro. coach...........
