Suspension (Moton Clubsport vs Moton Motorsport)
#46
Basic Site Sponsor
Basic Site Sponsor
And, FWIW, my car with spring rates approximately 1/4 of Chris's had the same amount of roll. It took awhile to figure that one out...
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
#47
Larry, I think you have it reversed, the spring rate is what transfers the weight around the car. If the car had no springs at all, it would effectively have springs of infinite spring rate and the weight transfer would occur immediately. The function of the dampers is to resist the weight transfer, so, increasing the compression in the front will slow down the weight transfer onto the front tires. You went the reverse of your desired outcome.
I'll let you think about that one for awhile...
I need to know what you learned about that.
#49
Answer to the first question:
Chris's car is a 993, mine is a 964 with 993 front suspension, so the fronts are identical and the rears are not since the rear motion ratio of a 993 is <1 and a 964 is > 1. We both have MoTeC ADLs with suspension position sensors which measure damper position and a math channel for wheel travel which is calculated from the motion ratio and damper position. At the time I was running 600/650 and chris at 2000+ F/R (I cannot remember exactly). My car is about 200lbs lighter than his car at the time.
#52
Basic Site Sponsor
Basic Site Sponsor
Geoffrey, I would argue that the shock does not resist weight transfer, it resists movement over time. The stiffer the shock is set, the faster and harder it resists this movement. In my understanding, the body will compress the spring and the shock. The force from both is transferred to the tire, however, the force from the spring will increase in a somewhat linear amount with movement, while the shock will exert force immediately respective of the amount of dampening it is set for.
#53
Basic Site Sponsor
Basic Site Sponsor
Probably comes down to roll centers. Even though you have the same front suspension, your rears are different, your ride heights are probably different and so the roll centers in your car are higher, therefore less body roll, allowing for lighter springs.
#54
Exactly, my car was approximately 25mm higher than Chris's, so although my center of gravity was higher, the suspension geometry had the roll centers closer to the center of gravity and therefore had less roll, not to be confused with weight transfer.
#55
I'm a nub at this but I was going to say the same thing, suspension doesn't prevent chassis weight transfer, it simply controls those motions and translates them to tires. You'd still have weight transfer if you were riding with no springs and hard rods.
#56
Basic Site Sponsor
Basic Site Sponsor
I have raised up and re-aligned several cars that were IMHO too low, all with good results.
#57
I'm surprised nobody commented on that. Isn't there disagreement here? My shock rebuilder (reputable) told me that measurements are done wheels-on-ground.
#58
Basic Site Sponsor
Basic Site Sponsor
I agree about all wheels on the ground. That is the operating condition.
#59
It will depend on the way the damper works. The Moton / JRZ / Protrac shocks are built where the canister pressure adds effective spring rate to the suspension. They need to be filled and tested with the damper unloaded (wheel off the ground). If you have airjacks it really isn't an issue. I check and set mine on a regular basis.
#60
[QUOTE=Geoffrey;6302255]It will depend on the way the damper works. The Moton / JRZ / Protrac shocks are built where the canister pressure adds effective spring rate to the suspension. They need to be filled and tested with the damper unloaded (wheel off the ground).
That is precicely why I jack up each side to measure canister pressure. I was wondering when someone would pick up on and question that procedure. There is also the issue of ambient. My measurement for this weekend at 32 ambient will be a different reading from the one taken at Road Atlanta in August, assuming no system leakage, which in my case is a poor assumption.
