Nitto NT01 review...
Old 12-16-2008, 11:11 PM
  #31
todinlaw
todinlaw's Avatar
Originally Posted by dmwhite
i've run them a few times now (same races as seth) and like them for what they are...the times that i ran them new (with full tread), i didnt notice any issues like you would full depth ra1's (tread squirm)...i qualified for the 13hr on a new full tread set and they felt fine right out of the box...
agreed...i'd say there as fast or a little faster than ra1's...i definitely like them better than full depth 888's
I thought the Nitto was made by Toyo same as the R888??
Old 12-16-2008, 11:13 PM
  #32
Veloce Raptor
Veloce Raptor's Avatar
Received 1,607 Likes on 836 Posts
yes
Old 12-16-2008, 11:17 PM
  #33
va122
va122's Avatar
I've raced on them in my e36 and ran them on my gt3. I run shaved RA-1s normally and the nittos are as close to RA-1s without being the same tire. Agreed on the less block squirm but not completely gone. Per Nitto they need about 2lbs less then the RA-1s due to the stiffer sidewall. Naturally not the same level of grip as the hooters but much better bang for the buck, I've gotten 2 race weekends out of them!
On the e36 I can't say they're faster then shaved RA-1s without looking at the data but pretty damn close. I really want to try them shaved as I used to shave the RA-1s to 4/32nds can take many heat cycles like the old standard
On the GT3 however, the 315s gave me more understeer then the 305 width RA-1s. at the time my car was stockish and i couldn't just click it away on the motons so i had to change the rear sway one hole. No big deal but annoying. I ran them full tread and noticed a weird wear pattern after a day on the track but again the car was stock and the alignment was perpetually off. I would buy them again once my beloved RA-1s get discontinued. I don't feel them being as fast as a shaved RA-1. I wish i had data to compare, unfortunately i just have my *** and my memory.
My 2 cents.
Old 12-16-2008, 11:18 PM
  #34
va122
va122's Avatar
correct, same compound
Old 12-17-2008, 01:03 AM
  #35
PedroNole
PedroNole's Avatar
Originally Posted by TR6
All this talk about being shaved while staring at the hottie in VR's avatar is getting to me.
Hey, that's my sister....
Old 12-17-2008, 09:49 AM
  #36
Veloce Raptor
She loves me still...
Old 12-17-2008, 10:27 AM
  #37
dmwhite
dmwhite's Avatar
Originally Posted by mglobe
Interesting comparison. Sounds like many here concur at least that NT1>=RA1. Any opinions on how the BFG R1's stack up against these?
completely different level of tire...the nittos and toyos are slower, longer lasting tires...the bfg's (and hoosiers and hankook z214's) are much faster tires...
i think one company owns the other or something like that...so, basically yes
Old 12-17-2008, 10:44 AM
  #38
RedlineMan
RedlineMan's Avatar
Grrrrrrr.....
I just wish that whatever company they are, they would offer some good old fashioned SIZES!
Old 12-17-2008, 10:50 AM
  #39
Veloce Raptor
Toyo owns Nitto.
Dave White is right. The Hankooks ROCK (as he said they would) but are a bit much $$$ wise for DE use on a regular basis, hence my experiment with another choice.
Old 12-17-2008, 12:10 PM
  #40
TheOtherEric
TheOtherEric's Avatar
Originally Posted by Pete
Nittos > RA1 > R888 (not a fan at all of the 888)...
Funny, that's exactly the opposite of what I expected. I haven't driven the Nitto NT01 but expected them to be slower just based on the price.
Old 12-17-2008, 12:40 PM
  #41
cgfen
cgfen's Avatar
Originally Posted by RedlineMan
Grrrrrrr.....
bingo
D*MN them for not making a 285 / 295 - 30 X 18 to go with their 235 - 40 X 18for us WB drivers.
315's are too big for my application
Craig
Old 12-17-2008, 09:18 PM
  #42
Martin Bishop
Martin Bishop's Avatar
Nittos really do not work over 40psi on 3300lb GT3. I have never gotten them shaved but 3-4 HC takes care of that. They let you know when they will break loose.
They talk to you when about to break loose and controllable once they do. If the audio was any good on this video you could hear what I am talking about. This is with maybe 3 or so HCs on them and a little too much psi
http://www.youtube.com/watch?v=FsZYGhYmoCg
Old 12-17-2008, 09:25 PM
  #43
sjanes
sjanes's Avatar
I found even 40 to be too high. I had never run RA-1's, but was told by the guys that ran them to try 40 hot (since the Nitto is supposed to be the same tire). I was not impressed with them for the first few sessions, so I started lowering the pressure and found 35-36 to be a lot better. For the money, they are a good tire.
Old 12-17-2008, 09:51 PM
  #44
multi21
multi21's Avatar
Received 3,370 Likes on 1,996 Posts
I found the max PSI on 3200 # GT3 was 38. ANYTHING over that and the car behaved completely different. 33-36 seems to be the sweet spot.
Old 12-17-2008, 10:35 PM
  #45
TedA
TedA's Avatar
Grrrrrrr.....
Roger dat...
Can't convince myself to try a set yet due to this..
Quick Reply: Nitto NT01 review...
