Does your cool shirt inlet pipe dribble into the cooler like this?
#91
So Shaffer looked at it and deemed it functions as it should and sent it back to you? I'm confused now on this one. It appears that water is coming in to the cooler at the prescribed rate (spec threshold) so what is the problem at this point? Is water flowing through the shirt? I know we all want to se you get a satisfactory resolution and I know Shaffer are very good people to deal with so there has to be a proper ending to this.
#92
Here are two data points you can rely on:
1. My CS dribbles at the 4oz in 10 seconds rate that CS specifies as normal.
2. Its cooling performance is normal. Feels about the same as every CS rig I've had, and this one is the third different pump I've tried.
#93
I did not measure the flow other than the ole "eyeball gauge". When I first got the cool shirt last summer, I, of course, took a peek at the inner workings of the cooler so I could see how fast the water was moving. I was impressed with the gusher of water coming into the cooler and remembered thinking that that high of a flow rate might perhaps melt the ice more quickly.
Now, the rate is appreciably slower, that slowness being very evident in reduced coolking effectiveness. Last summer, the cold water would slam into the cool shirt like Zeus lancing me with a frozen lightning bolt. Now, I sit in my car thinking "Is this thing working?"
I am going to try running the cooler with the engine running as a last-ditch effort before I call Shaffer. When I first tested it last year, the engine was not running, and the pump worked perfectly.
Thanks, TK.
#94
When I have the connections reversed it was flowing about 1/2 and when i corrected the connections the flow was exactly what they said it would be. (just fyi)
Mike
Mike
#97
THat's about how I made my first cool shirt system.
FWIW, the standard retail coolers suffer from a slosh leakage problem. They are not even lightly sealed around the lid, and they dump water when cornering until they are sufficiently emptied to prevent further spillage. The early cool shirt coolers were the same, and everyone had the same problem. A couple of years ago, Cool Shirt came out with coolers that have nicely sealed lids with positive locks. These are the only coolers I know that solve the slosh problem, but I couldn't find a source aside from the Chinese manufacturer who only sells in LCL lots.
I am working on building a cool suit system. It is mostly done right now, but still needs a few touches. If it works out really well I may consider making them to sell. Right now I just need to make sure my prototype works.
#98
I just spoke with Tom at Shaffer, a very nice guy. He said that the flow rate should be 4 oz/10 seconds. I did test it and, lo and behold, the flow rate is about 4 oz/10 seconds. Technically, there's nothing wrong with it, at least as far as Shaffer's minimum guidelines are concerned. Additionally, I did notice that one of my connections wasn't connected properly, but this situation had no bearing on the flow rate once rectified, nor did any water leak out as a result of the condition.
I did mention to Tom that my cooler definitely moved water far faster last year when I first got the cooler. There exists the real possibility that my first pump had an exceptionally high flow rate that mysteriously dropped after a few months.
Sitting in the car while wearing the cool shirt, I could feel it coursing through the tubes . . . but it still didn't feel as good as previous tests. I, however, cannot argue with the fact that it is meeting the minimum flow rate.
#99
Mark, just to give you another data point. I just took delivery of my new (to me) race car and it had a cool shirt system in it. the cool shirt cooler seems to be a much older one (pic attached) compared to my new one pictured in post #6. I also unscrewed the motor so I could get a good shot of the type, etc, for you.
Since there is no cover in the old one I figured I'd test it out....stopwatch for ten seconds and a measuring cup with tube in it. Results??? I got 7 oz in 10 sec.
My guess is that your motor is NOT getting a good power level supply. Have you tested the connection for volt level?
#100
I always look at the clear hose that plugs into my shirt after I hook it up and turn it on for a quick test before hitting the track. You should see the bubbles move through the tube fast, then it will fill with water but you can still see how fast the fluid is going when debris or small bubbles go by. It should be going by quite fast. If not, there is a problem. Recently my FAST cool suit has has some slowness but it seems ok after a while. Sometimes I think a piece of ice may block the inlet?
#101
