Does your cool shirt inlet pipe dribble into the cooler like this?
Old 07-29-2008, 12:04 AM
  #61
Mark in Baltimore
Mark in Baltimore's Avatar
Just got my Cool Shirt back. Here are some photos of the new pump. Gary, is this the same blue and white one that you are still having issues with? Also, I included photo of the new maintenance additive and accompanying label. I hope this corrects the issue since my patience tends to be very limited for sending things back.
Old 07-29-2008, 11:51 AM
  #62
Gary R.
Gary R.'s Avatar
Yes, that is what I just removed Mark. What the heck is "Maintenance additive"?
Old 07-29-2008, 12:26 PM
  #63
Mark in Baltimore
Dunno. We need a chemist to analyze the fluid.
Old 07-29-2008, 11:25 PM
  #64
mikew968
mikew968's Avatar
It is a fungicide to keep fungus from growing and clogging the tubes and a substance like water wetter to make everything flow better.
Mike
Old 07-30-2008, 10:09 AM
  #65
Mark in Baltimore
Thanks, Mike. Is there an online source for this concoction?
Old 07-30-2008, 11:12 PM
  #66
mikew968
mikew968's Avatar
They sell it in 24 count boxes. So someone would have to buy 24 from Shafer and sell individually. Check with the normal suppliers like CDOC.
Mike
Old 07-30-2008, 11:18 PM
  #67
Gary R.
Gary R.'s Avatar
Ask how much?
Old 07-30-2008, 11:24 PM
  #68
Mark in Baltimore
Thanks, Mike, I know that. My question is who sells the generic fungicide and generic wetting solution that you say is in the Cool Shirt bottles? Do you know for certain that there is fungicide and a water wetter? Thanks.
Old 07-31-2008, 07:48 AM
  #69
LVDell
LVDell's Avatar
Cool Shirt says in their instructions for use to use a ALCOHOL solution through it so crap doesn't grow inside. I am pretty sure you could cycle a bleach solution every so many uses and drain thoroughly (tubes, shirt, box) and you should be fine.
Old 07-31-2008, 11:54 AM
  #70
Mark in Baltimore
Originally Posted by LVDell
Cool Shirt says in their instructions for use to use a bleach solution through it so crap doesn't grow inside. I am pretty sure you could cycle a bleach solution every so many uses and drain thoroughly (tubes, shirt, box) and you should be fine.
Putting bleach anywhere near my all-black Recaro seat or race suit makes me really nervous . . .
Old 07-31-2008, 11:57 AM
  #71
Gary R.
Gary R.'s Avatar
I do it out away from the car, let it run through for 10 minutes or so, then drain it all out.... but I use Isopropal...
Old 07-31-2008, 12:00 PM
  #72
Phokaioglaukos
Phokaioglaukos's Avatar
Cool Shirt says to use alcohol (rubbing alcohol is ok, keep the good stuff for drinking), not bleach:
Once per month, pour one pint Isopropyl Alcohol (rubbing alcohol) in the cooling unit with the ice and water while the unit is being used. This will keep the pump, hoses and shirt lines clear of the buildup that occurs naturally in water-circulation systems. Wipe out cooling unit after each use.
Link is here: http://www.coolshirt.net/faq.html
Old 07-31-2008, 12:06 PM
  #73
Mark in Baltimore
Bleach is a funny liquid. It doesn't take much for it to stain a dark fabric. You have to be a fanatic about flushing the system thoroughly.
Old 07-31-2008, 01:08 PM
  #74
LVDell
LVDell's Avatar
I knew I screwed it up! Scratch the bleach comment and sub alcohol
Old 07-31-2008, 01:25 PM
  #75
Gary R.
Gary R.'s Avatar
Sorry Mark, I was talking about Isopropal alcohol, I completely missed Dell's bleach remark... no bleach please...
Quick Reply: Does your cool shirt inlet pipe dribble into the cooler like this?
