5 pt or 6 pt harness for DE?
I'd only use a six-point, and after witnessing an SRF accident in which the driver got to go to the hospital for emergancy surgery to repair his ******* and other damaged parts that were injured by the sub belt (5-point), I wear a cup too. It might not be as comfortable, but I bet that surgery wasn't too comfortable either. Fortunately the young man (he was like 17 at the time) was expected to make a full recovery!
OK Dell...
Be that way.
Alright, nitty gritty. If a single sub is configured properly, it does not touch your body! A properly setup double sub DOES. In that sense, it is "less comfortable," whether sitting still or going around the track. Then, this level of comfort varies depending on the style and configuration. However, if you crash and hit the sub, it is rather obvious which is less... um... injurious.
Like I said, you need to make an informed decision beyond what I offered previously. There are two main factors at work here, in my estimation.
1) Are you likely to have an accident? The average DE driver is NOT likely to crash, ever. As I mentioned before, the advantage of a good 6-point is moot if you don't crash. Beyond that statement of fact comes your personal judgement and risk assessment.
2) All belt systems require mods to the car to get the sub in. It is VERY easy to say "go get a 6-point, end of story." However, to do a PROPER geometric install for a 6-point system is NOT EASY. It is very difficult to even find a seat that accepts them, and beyond that you have to have TWO mount points, in the RIGHT PLACE, in order to retrieve the advantage the 6-point offers.
You need to make a judgement of your level of risk, factor in how much you want to modify your car and seat to get the 6-point to work properly, and then if you even have anyone who knows how to properly configure a 6-point. Remember that if you do not set it up properly, the 6 point offers no advantage... other than Kiddie Klearance, IF you hit something.
For the record, I used to run a Simpson 5-point. It was utterly comfortable and performed perfectly. I now have a Schroth Hybrid 3/2. It performs better only in terms of lap belt positioning because of the sub slide adjusters. I have the Schroth to set a good example, to show clients, and because I admittedly like the trick factor. I also understand the advantages, and can reap the potential benefit of them because I know how to configure them.
Be that way.
Member - times 3
Member - times 3
Our safety chair, John Melvin, will tell you that five point harnesses do not work. He suggests that drivers only use a properly installed six point, with the sub straps mounted behind you, perhaps to the same mounts as the lap belt. For those of you not familiar with him, google John Melvin Safety.
With all due respect, Patrick...
I don't think the highly estimable Dr. Melvin would mean that as litteraly as it appears in your post, even if he said it thusly. In relative terms, and if both are available, and if you can get a 6-point configured properly, then it IS INDEED a better choice. No brainer. The only problem is getting there.
I would wager that AT LEAST 50% of the 6-point systems out there are not optimally arranged. I would also say that anyone who thinks it was "easy " to install their belts did it wrong!
There is nothing easy about doing it right, and further, there a lot of "ifs" in saying a 6-point is better. I'd rather see someone have a good 5-point than a poor 6 any day.
I am also considering adding a harness for DE only use. I understand how the 5-point works, but I'm a little confused on how the 6-point actually works. Does it go through a substrap hole like the 5-point, or does it run out the sides?
I say don't do 4/5/6 points without a roll bar/cage.
6 pts are more comfortable and provide quicker loading of the hips in an accident(which is a good thing). I'll be at the DE this weekend if you want to try my setup(6 pt Schroths), black 330Ci in white.
I've been holding off on installing my 6 points in my 944 because of how hard it is to properly mount them. I must say John is like the little angel/devil on my shoulder as I try to plan the configuration. In the 944 there just isn't any hard point to mount the sub belts to other than just drilling and using a backing plate.
I really don't want to drill holes, and going to the lap belt mounts is less than ideal, though many say to set it up that way. Certainly not something I want to take a chance and get wrong.
I do feel a bit safer with one of his harness bars... it's just that it is far easier to install that thing than it is to actually figure out the harness placement. That's a job for the off season.
