911 front fender louvres??
Old 12-15-2015, 01:18 AM
  #31
Cory M
Cory M's Avatar
For the record the Crawford and KMR louvers are one in the same, made by Crawford for KMR. I called Crawford about them several years back and was quoted an outrageous price too.
Old 12-15-2015, 01:21 AM
  #32
HiWind
HiWind's Avatar
Originally Posted by 333pg333
Are you allowed to run a 935 style fender? Totally open at the rear. Agreed on the vents being positioned further back. Also the front louvre should be steeper than those behind it in general terms.
996 cup .... Can't imagine how to do that re open back
But interesting pics ... Where did you source yours on the beastie?
Originally Posted by jdistefa
Crawford makes 'em for 993. God only knows what the price is
Their website seems to be hacked
Originally Posted by Tom '74 911
I saved this photo from somewhere a while ago - can't remember where I found it... Kind of interesting though.
Thanks Tom
Old 12-15-2015, 02:23 AM
  #33
flatsics
flatsics's Avatar
For a 944, but you may be able to modify them.
http://www.allporscheracing.com/Racing.html
Old 12-15-2015, 02:34 AM
  #34
flatsics
flatsics's Avatar
http://zerodecibelmotorsports.com/products/
http://zerodecibelmotorsports.com/pr...-fender-vents/
Old 12-15-2015, 02:35 AM
  #35
flatsics
flatsics's Avatar
Same as above just installed
Old 12-15-2015, 02:47 AM
  #36
333pg333
333pg333's Avatar
Originally Posted by HiWind
Winder - Please explain what you mean by recess? Are the vanes quite high?
Flat6 thanks!
The ones in post #17 are proud, as in sit above the profile of the fender where the ones in posts #27/8 are flush and therefore the louvres are actually recessed under the line of the fender if you get my meaning.
Thanks Tom
Anything's possible. You just need to find a f/g or c/f fabricator that will make up the panels. As some have already suggested, the Crawford ones are expensive although nobody has said how much. We got some of our panels made by http://www.allporscheracing.com/ in the US. Speak to Mike from IFC. He makes up f/g parts for 944 stuff but I'm sure if you asked if he would do a run for the 911 guys. He'd at least give you a yes or no and then possible costs. My only concern would be the different radii of various 911 variants? He made the 935 or F40 front fenders for our car and the louvres in them. Plus the side rockers. (We've modified since then) We were going to revise the vents so that the front louvre was steeper and higher than the rest. This creates some 'draw' and helps to pull the air out. This is why 'proud' vents are better (more efficient) than recessed ones. We made the central vent for the cooling cores and also the ones directly behind it. The outer ones in the hood are not really very efficient. Made by someone else again.
Old 12-15-2015, 02:54 AM
  #37
333pg333
333pg333's Avatar
EDIT: You beat me to it Doug. Those very same louvres in your post #33 are on my car in post #36. He was going to modify them and send me version ii but it has gone onto various back burners as they say.
Old 12-15-2015, 08:07 AM
  #38
Krokodil
Krokodil's Avatar
Originally Posted by winders
Yes, I remember seeing those. I sent an email to them asking about them and no one ever responded. I guess I should call......
Scott
Call Dwain or Roland at 949.770.2888. I know he a few sets in stock as I saw them in Dwain's office.
Cheers,
Old 12-15-2015, 10:33 AM
  #39
HiWind
HiWind's Avatar
Thanks Doug those triangular ones look great and likely easier to fit
Cheers for the input too Pat
Old 12-16-2015, 08:47 AM
  #40
pete95zhn
Former Vendor
pete95zhn's Avatar
zerodecibel's vents seem to had the best price/looks value. Not too expensive for testing how they adjust to 996's curved fenders.
Still interested to know Vision's vents' price though.
Old 11-01-2016, 03:52 PM
  #41
wanna911
wanna911's Avatar
Visions price is 750.00
Old 11-02-2016, 02:39 PM
  #42
mark kibort
mark kibort's Avatar
Has anyone just cut vents in the aluminum and bent them up slightly? or just did 5-6 thin rectangular openings cut in the fender? afterall, we are trying to vent wheel well higher pressure air to the low pressure in that section of the fender. I suppose the vent ducts could create a Bernoulli effect and draw even more air out too.
Mike, what is your main objective here?
Old 11-02-2016, 02:41 PM
  #43
mark kibort
Originally Posted by flatsics
that would be more of an inlet vs a vent. thats a high presure zone on the fender top
Quick Reply: 911 front fender louvres??
