Carrera GT 1st service @ 4 years ?
My dealer told me my 2004 GT being 4 years old ( 1,400 miles ) needs a service - engine out, which includes a factory recall while the engine is out ???? Has anyone had the first service done - what does it include and what estimated cost ? Howard Jacobs
I think you need to find a new dealer!
Unless you need a new clutch I can't think of any reason to remove the engine. You have had the oil changed since new I hope, just because you have such low mileage doesn't mean the oil is good for four years.
Certainly in the UK at four years old/30k miles it's an engine out service.
This is an email from Porsche Cars GB confirming this to be the case, and that the engine needs to come out for a recall/campaign item so this is done at the same time:
'I need to advise you that now having just done 4 full services on Carrera gt's, we have to remove the engine and gearbox to be able to measure and adjust where necessary the valve clearances
There is also an outstanding campaign on your car, which involves replacing the gearbox input shaft plate, this can only done when the car is having a full service or any other work that involves removing the engine and gearbox.'
Around £7k GBP. Mine's due the end of this year, however at 18k miles the clutch is still at 29.70mm so that will not need changing!
I would worry about many other things in a four-year old car which has only done 1400 miles. Not to be picky, but how do you keep everything in running order when you don´t run it? Are you keeping the miles low on purpose?
Professor of Pending Projects
So let me see if I understood this correctly... Porsche has a recall that they are not willing to pay for? They want to do it when you are paying for an engine out service? Wow...
Anyway... I was under the impression that you needed to do an oil and brake fluid change every year (or two) if you only put a few miles in the car... just to make sure you get rid of any condensation in the fluids...
I asked my dealer to have a look and he said that there was only a tiny inspection hole too small through which to see anything useful.
![](http://i6.photobucket.com/albums/y211/993rsr/PAGE2.jpg)
![](http://i6.photobucket.com/albums/y211/993rsr/PAGE1.jpg)
