Received my new PIWIS III
#376
Originally Posted by runbuh
That's all Race Track mode is. It's so you can have a set of lower pressures you run on your tires during track days without tripping pressure warnings (as I understand it - I don't own a 992). That's just build in MFD/TPMS functionality that you don't need to activate. Are you saying you don't have this TPMS option at all on your 992?
I think that's part of the track mode that the GT3 has in lieu of sport/sport+. That also changes the gauges, brings them to the side of the tach, where you can actually see them. Tire pressure on one side, car data on the other. Between the gauges and the tach, progressive lights for changing gears.
https://rennlist.com/forums/992/1241...k-display.html
#377
Not usually available. The menu is there but nothing happens if you try to act upon it.
Looking at a post you made back in February, with the screen shot showing the track mode setting in PIWIS, did you poke around in this option to see if it enabled the gauges (select something other than "Sport Chrono")? This is for "Selection of additional instrument".
#378
Thanks.
#379
Cut off the time sync for the VM (VMware setting), and go into the time settings within the VM (Windows 8.1 time settings) and tell it not to pull the time from the internet.
#380
#381
If you're running Windows on your main computer (not the PIWIS VM), I suggest you google for stopping VMware time sync. There may be other settings you need to make in VMware.
Like this article:
Disabling Time Synchronization (1189) (vmware.com)
Like this article:
#382
#383
Has anyone got a copy of piwis v39.900 or v40 with developer mode? I have access to a 2021 macan for a few days and desperately want to get a FAP/VAL from it before it goes back(see what's changed new etc).
Re date you can create a very simple batch script which runs on start up of vm.
#384
May be can contact.
JB911 (04-19-2021)
#385
#386
#390
