Macan 2014-Current
Transmission problems...beware
Old 02-15-2023, 09:37 AM
  #241
BJBvirginia
BJBvirginia's Avatar
I had the exact same issue (67K miles) happen to me last week. Car is parked in my garage right now trying to figure out what to do. Any suggestions where to take it?
Old 02-20-2023, 07:13 AM
  #242
greenmileshrek
2nd Gear
greenmileshrek's Avatar
Originally Posted by BJBvirginia
I had the exact same issue (67K miles) happen to me last week. Car is parked in my garage right now trying to figure out what to do. Any suggestions on where to take it?
If your username is anything indicating where you're at, there's a shop in Chantilly, VA called GT Peace. It's worth giving them a call. I talked to them a few weeks ago about the potential for a mechatronics unit replacement out of precaution based on @Olddragger 's debacle over the last 2 years.
Alternatively, @VAGfan has had suggestions throughout this thread on Audi/VW mechatronics parts that may swap right in if you're mechanically inclined. I have noticed there are non-US mechatronic units available for a few grand (1-2) instead of the "Porsche units" which are ~8k. maybe the QC is different for different factories? But based on Ford's Mustang Chinese manual transmission debacle a few years ago I have a strong feeling it doesn't matter...
Old 02-20-2023, 01:03 PM
  #243
VAGfan
VAGfan's Avatar
There is no difference in "Porsche" mechatronic units/parts versus "Audi" mechatronic units/parts, they all come out of the same VW/Audi/Borg-Warner transmission factory in Kassel Germany.
greenmileshrek (02-27-2023)
Old 02-20-2023, 08:55 PM
  #244
daaa nope
daaa nope's Avatar
ATL Speedwerks in Gainesville, GA (just outside of Atlanta) does PDK rebuilds. Former big IMSA shop racing the Honda Civic in the old Conti series - but Todd (owner) is a longtime Porsche guy and they do a LOT of Porsche work. I'd give them a call if you're in VA.
Old 03-06-2023, 04:46 PM
  #245
topkerel
8th Gear
topkerel's Avatar
Having the same issue, car lost reverse gear. Does anyone know good mechanics in Massachusetts or New England?
Old 03-06-2023, 07:00 PM
  #246
95_993
95_993's Avatar
EPE in Natick
The following 2 users liked this post by 95_993:
topkerel (03-07-2023), TripleL (03-09-2023)
Old 03-08-2023, 12:41 PM
  #247
topkerel
8th Gear
topkerel's Avatar
Originally Posted by 95_993
EPE in Natick
Thanks for the recommendation. I just got the report from dealership and they wanted a new transmission for $30k+, I sent the diagnosis to EPE and they said probably do need a new transmission. The cost for transmission is way over the resale value for a 2016 Macan S. I’m not sure what to do now..
Old 03-08-2023, 12:49 PM
  #248
VAGfan
VAGfan's Avatar
What were the specific findings and/or DTC error codes? Can you post the "Report"?
Very few types of failures require the replacement of the entire transmission.
Old 03-08-2023, 01:24 PM
  #249
topkerel
8th Gear
topkerel's Avatar
Thank you. Here is the diagnosis report. The communication issues might be battery related but I haven’t had any battery warnings so not sure. I just got in touch with a local repair shop they are willing to take a look, waiting for the tow truck to come now.
Perform Val check for codes found numerous codes stored in transmission unit U012100 - No communication with PSM control unit
U012600 - No communication with steering wheel electronics control unit (CAN bus, chassis)
U014000 - No communication with front-end electronics control unit
U016400 - No communication with A/C system
U021200 - No communication with steering wheel electronics
P174100
- Clutch pressure adaptation ? adaptation limit reached
P17D800
- Torque limitation due to clutch temperature
P17D600 - Clutch 1, pressure ? above limit value
P17D000
- Clutch 2 ? slip too high,
transmission will engage reverse but will not move when accelerating, also starting to do it in drive, Inspect harness, looks okay , internal failure of clutch 1 and 2 in transmission unit deciined transmission assembly
Old 03-08-2023, 02:09 PM
  #250
VAGfan
VAGfan's Avatar
The "No Comm" codes are puzzling, but that sounds like Problem #2. It is possible that the root-cause of these Comm problems might be with the other modules (or the wiring of the CAN bus) that they share (nothing to do with the transmission itself).
Problem #1, an issue with the clutches, is most likely an internal issue with the Mechatronics unit, which can be easily removed with the transmission remaining in the car. A thorough inspection of the Mechatronic might reveal a problem with one of the solenoid valves, or the interconnect boards, which can be easily replaced. You can even buy a rebuilt Mechatronic unit from them, and just reuse your old TCU (transmission control computer) with the rebuilt Mechatronic. (The Mechatroninc consists of a "valve body" plus the TCU transmission control module)
The Macan PDK transmission is an Audi "DL501 / OB5 / DSG / S-Tronic" unit. Lots of repair parts can be found here: 0B5 (DL501) ⇨ Maktrans - automatic transmission parts online shop
They are located in Europe, I have ordered some parts from them, they are legit.
More parts (USA vendor): Audi B8/B8.5 S4 Quattro 3.0T DSG Transmission Parts - ECS Tuning
If the Mechatronic is OK, then it is possible that the clutches are worn, but the transmission must be removed from the car to replace them.
How many miles on this car?
topkerel (03-08-2023)
Old 03-08-2023, 02:24 PM
  #251
topkerel
8th Gear
topkerel's Avatar
The dealer did mention needs new battery so I assume that’s causing communication issues. The car is at 83k miles, mostly driven in city. It has sports chrono package so occasionally lunched, but I won’t say total more than 15 lunches over last 3 years.
One side note, might be unrelated. We last month had an extreme cold weather at sub10 degrees, that was the first time I felt the shift jerking a little bit. Although it’s back to normal very soon after the car warmed up.
Old 03-08-2023, 02:38 PM
  #252
VAGfan
VAGfan's Avatar
Also, clear the codes, then try to drive the car and see what codes come back. The Comm codes could have been from a low system voltage (weak battery) when you tried to start the car in the extreme cold.
Old 03-08-2023, 03:28 PM
  #253
topkerel
8th Gear
topkerel's Avatar
Thank you so much VAGfan. I am having my car towed to Revolution Automotive Services in Norwood, MA. They seem pretty knowledgeable with Porsche. I will send them this thread for reference, will update on what happens.
Old 03-08-2023, 09:45 PM
  #254
DIYDanCars
DIYDanCars's Avatar
Have you ever had the PDK transmission serviced? Porsche recommends a fluid change every 4 years or 40k miles.
This is exactly why I will never own a newer Porsche out of warranty. These cars just don't hold up like they used too.
https://www.pcarwise.com/local-help/...n-maintenance/
Old 03-08-2023, 10:52 PM
  #255
topkerel
8th Gear
topkerel's Avatar
The PDK service was done by previous owner at 40k, the 80k service was planned to be done this summer.
I agree I should have extended the warranty after CPO expired. Just many people, online and in real life, saying how Porsche is reliable, which made me decide to take chance. I used to own an e90 with N54 engine, never dared to have it out of warranty lol.
Quick Reply: Transmission problems...beware
