Sponsored by: APR
strut tower failure
Old 11-21-2016, 02:55 PM
  #136
stout
stout's Avatar
Received 1,309 Likes on 609 Posts
Originally Posted by sonorous
I posted the link earlier in this thread...
Thanks for that. Was trying to remember where I saw it...and it was here.
That car looks like it's been modified with aftermarket wheels. Curious which strut top that is.
Old 11-21-2016, 02:56 PM
  #137
okie981
okie981's Avatar
Location: On a pygmy pony over by the dental floss bush
Originally Posted by stout
I seem to remember seeing the same failure mode on a white 981 Cayman or Cayman S. Went over a curb, and it looked like a hard hit. Pretty sure I saw it here on RL. Did a fast search late last night, but couldn't find it; I'll look some more when I get a bit of time.
All non-GT car info about these failures is helpful to try and understand this. I don't agree that this shock tower rupture is acceptable, under any circumstances. It should have been stamped metal. Having said that, I'm more interested if any non-GT cars had this failure from "normal" use. Normal meaning thrashing the crap out of it on a race or autocross track, or driving on very rough public roads. For example, hitting a vertical curb that blows the airbags would not be normal use, so if the shock towers rupture there, so be it, I guess.
Old 11-21-2016, 03:31 PM
  #138
stout
stout's Avatar
Agreed. All cases are worth looking at, and the cases so far suggest there will be more, or already are.
White Cayman S's impact looks severe and well outside any definition of normal use—but hard to say how bad the impact was vs. the outside sheetmetal damage...and one wonders if a stamped steel shock tower would have failed. My gut guess based on all previous experiences seen says no, but that's all it is—a gut guess.
What strut top is in that white car? Curious about it, as it looks like the car was modified. Need to go back and look at the wheel for obvious damage, too.
Old 11-21-2016, 05:26 PM
  #139
Joe Weinstein
Joe Weinstein's Avatar
Old 11-21-2016, 05:27 PM
  #140
okie981
okie981's Avatar
The strut top looks to be the OEM part for 981/991 non-GT cars, just like the one in the photo of my BS earlier in this thread. And that's the same strut tower as in all 981/991 cars. Pretty nasty impact, but I believe like you, if it were stamped metal there would be no ruptured shock tower. Maybe a tweaked uni-body frame though. And the aluminum front sub-frame is another subject altogether as far as how it takes these impacts. But lots of cars are made with aluminum sub frames these days. BMWs, Audis, others I'm sure. I wonder if other OEMs are using cast aluminum shock towers......
Old 11-21-2016, 05:29 PM
  #141
okie981
okie981's Avatar
Originally Posted by Joe Weinstein
Ugh!! Man, that sucks so bad. Will be watching to see how the dealer handles this.
Old 11-21-2016, 06:42 PM
  #142
stout
stout's Avatar
I remember early aluminum Audi cars, like the first A8, being kinda unimpressive in terms of their weight savings vs steel unibody cars. Yes, aluminum is lighter than steel, but when it is used for structure, you need more of it.
The metal in these 981/991 shock towers is THICK, but clearly can't take the sharp inputs that stamped steel towers have weathered for decades, even in rusty old Porsches with 300,000 miles. Wonder how much weight they saved...
Old 11-21-2016, 07:05 PM
  #143
okie981
okie981's Avatar
Or $$$, if any.
Old 11-21-2016, 08:06 PM
  #144
stout
stout's Avatar
Or $$$, if any.
Pretty sure these failures are undoing any marketing value-add, one $$,$$$ failure at a time. Hopefully, the folks inside are on it. I suspect someone like Mike Levitas could come up with a fix for this with a car on the lift, a beer in hand, and an hour to think about it. Porsche might be a bit quicker yet—if the right team can get through the red tape.
Old 11-21-2016, 09:53 PM
  #145
okie981
okie981's Avatar
The metal in these 981/991 shock towers is THICK, but clearly can't take the sharp inputs that stamped steel towers have weathers for decades, even in rusty old Porsches with 300,000 miles. Wonder how much weight they saved...
I'm guessing they saved about 3 lbs in weight total per car and $15 per car in material cost.
Old 11-22-2016, 01:35 AM
  #146
Alan C.
Alan C.'s Avatar
Received 1,042 Likes on 535 Posts
Pretty sure the cast aluminum parts are more expensive than stamped steel parts.
Old 11-22-2016, 08:24 AM
  #147
okie981
okie981's Avatar
The cost may be very close either way. It's been a while since I did automotive component design, so I'm a bit rusty on cost estimating. Also depends on the amount of post-processing after the casting or stamping process.
Old 11-22-2016, 08:55 AM
  #148
4carl
4carl's Avatar
Received 1,138 Likes on 607 Posts
They saw a need to reinforce the rear strut towers, but not the front except on the club sport which is a track car. Yet they market the street GT4 as a street car that is designed to track with the same strut tower as a base 981 boxster??
Old 11-22-2016, 09:26 AM
  #149
texasviany
texasviany's Avatar
Curious....I added JRZ pro...will this make the failure more probable or less so. On one hand, it won't easily bottom out. On the other, the springs are a lot stiffer.
Old 11-22-2016, 11:34 AM
  #150
RDCR
RDCR's Avatar
The bigger question is would Porsche deny a warranty claim if one has non OEM dampeners or springs and has the failure?
Quick Reply: strut tower failure
