0Q Pure White - journal
You're right, any oil whatsoever in the intake system will lead to some carbon buildup on hot parts. The OEMs have to deliver something that doesn't vent crankcase vapors directly to the atmosphere while also keeping crankcase pressures from building up due to compression and combustion pressures leaking around the piston rings. Also have to prevent ignition sources from making their way to the crankcase vapors in order to prevent inadvertent explosions. A simple example of that is the PCV valve on the valve cover of an older Chevy V8. That PCV valve only serves one purpose, to prevent a backfire in the intake manifold from reaching the vapors in the crankcase. I'm thinking there must be some type of flame arrestor or check valve in the 981 crankcase-to-intake system you removed the tube from? Venting to exhaust would work if you had a check valve like you said, but wouldn't you also need to keep crankcase pressures from building up and depending on exhaust back pressures that check valve might not open to vent the crankcase?
Maybe a check valve wouldn't even be needed if it was routed into the exhaust, as the flow would create a draw;
http://www.audizine.com/forum/showth...V-into-exhaust
The exploding crankcase reminds me of my previous life working as an engineer for a company that made giant 20,000 horsepower engines for pumping natural gas across the US. I was told a story by a co-worker there about a crankcase explosion that blew a refrigerator sized hole in the side of the crankcase and it killed a guy. A misfiring cylinder allowed enough combustible mixture to build up in the crankcase and some ignition source lit it off. Boom. That engine was a V20, twin turbo. The turbos weighed 6,500 lb each, and one connecting rod cap weighed 600 pounds. Intake valves were about 5 inches in diameter, 2 per cylinder. I'm 6'2" and 200 (at the time) and I could easily stand up in a cylinder with the Pistons removed.
But I digress.
Thanks again for the excellent post.:thumbup:
But I digress.
Location: On a pygmy pony over by the dental floss bush
Cooper-Bessemer Z330 (20,000 hp) and W330 (10,000 hp), both run at 330 RPM at full rated power. I'd love to see Leno put one of them in something. They're the size of a 2 bedroom apartment .
935 miles - CEL comes on the second time I start the car after switching to the larger 82mm TB.
_
980 miles - No longer get the CEL when starting the car, so I assume a TB adaptation has taken place.
_
Not sure I feel the difference, but knowing it's no longer dumbed down compared to the 991 makes it worth it to me.
Here's a dynamometer comparison on the 3.4L;
http://ipdplenums.com/news/dyno-prod...ster-dyno-test
d00d- I spoke to the Head Mechanic at me dealership.They said they can do the Install on the upgraded IPD. When they do this what precisely do I need to tell them to do so the TB will adapt. Do I need to tell them to get into the ECU and make some adjustments. This part does not seem to be clear to me.
I did the install myself and didn't do any PIWIS II adaptation.
Maybe there is an adaptation routine built into the ECU that is automatically triggered, or perhaps the procedure in IPD's 987 install document that I followed was applicable.
Depending on the car it could stumble and run erratic before an adaptation, but I didn't experience that.
Someone posted that COBB now has a GT4 tune that either prevents the CEL aor fixes the non Sport button high RPM off throttle hang.
987.2_DFI_Installation_Guide.pdf
I don't see how VTA could negatively impact the warranty, unless having clean valves is somehow looked at as taking away cleaning service revenue.
Did you just leave the car alone or were you resetting the CEL? I've reset mine each time it comes on and am about 8 drive cycles in and am still getting the CEL. I'll give it some more time and hope it resets itself but it hasn't thus far. (I have the IPD Plenum and 82mm throttle body, but with a cobb Accessport tune.)
I didn't reset the CEL, it just went away after maybe two drive cycles.
Didn't you mention in another thread that there's a COBB v102 tune that takes care of the CEL so it doesn't need to be reset?
Checked their site but didn't see it, maybe it's beta.
