Sponsored by: APR
A Killer Croc - My Cayman GT4 Ownership Journal
Old 08-23-2015, 06:17 PM
  #31
fishing
fishing's Avatar
Great thread!! Thanks for the pics! The car looks great!
Old 08-23-2015, 06:35 PM
  #32
jfr0317
jfr0317's Avatar
Thanks for doing this thread, and congrats on the car!
Old 08-23-2015, 06:41 PM
  #33
TechnicGravy
TechnicGravy's Avatar
Great info and pictures!
FYI, my 991S used about 1/2-1 quart of oil every 5000 miles. I would expect the GT4 to be about the same unless you are heavily tracking it.
Old 08-23-2015, 08:22 PM
  #34
Accel Junky
Accel Junky's Avatar
Old 08-23-2015, 08:32 PM
  #35
Accel Junky
Originally Posted by konaforever
Nice write up so far! Congrats!
Thanks!
Originally Posted by RealityGT
Great write up.
Originally Posted by Quikag
Great post!!
Originally Posted by Rob VN
Congratulations on getting your GT4 home.
I am going to put an LN Engineering spin on filter on my car. (When I get it )
Thanks! I'm very glad to have this process concluded.
Originally Posted by ShakeNBake
thanks for all the pics
No problem, more to come I assure you!
Originally Posted by equ
Great thread, extremely clear and informative. Looking forward to more!
More shall come!
Originally Posted by 981GT4
Beautiful car and will be following your write-ups.
Your front lower brake duct picture provides the perfect view to compare the smaller duct versus the larger duct. Don't know why my car was out fitted with the larger version, when neither the 991 GT3 or GT3RS utilize this larger duct.
Small front lower brake duct
Thanks! I figured that would come in handy as I was surprised to see the two ducts myself.
^Great info in this thread
"Front total = 46.24 lbs minus 23 lb tire weight results in front wheel weight of approximately 23.24 lbs
Rear total = 54.86 lbs minus 29 lb tire weight results in rear wheel weight of approximately 25.86 lbs"
^Those weights aren't bad for 20" wheels..
Not bad at all. But could be improved upon too. Good compromise!
It is all my pleasure I assure you and thanks!
I will try to give you guys an idea once I do the first full oil change.
Old 08-23-2015, 10:06 PM
  #36
Dyim
Dyim's Avatar
Received 1,027 Likes on 550 Posts
Your interior pic is reassuring. I was always concerned that black leather/ platinum stitching/ CF/ alcantara (what I want also) might be too dark or 'black'. But I guess they are different 'shades' of black and goes well together.
Old 08-23-2015, 10:32 PM
  #37
supercup
supercup's Avatar
Originally Posted by Accel Junky
Brought this over from my delivery thread:
Compared the M3...hmm. I would say that the ride quality is somewhat similar comparing the normal setting in the GT4 to the M3 (mine has non-adjustable suspension and it is rougher than you would expect for a BMW) with a slight edge in comfort going to the M3.
The M3 has much better visibility. The M3 seats are a little more comfortable in that they accommodate my shoulders/back whereas the GT4 standard seats are tight around the top bolsters and force my back/shoulders to sit on them rather than in them. The M3 cruising sound volume is much more tame even with the M3's exhaust valves locked open (exhaust valve mod). Much less tire noise. The gas mileage is very similar between the two cars. I usually average about 22mpg with mixed driving in the M3 maybe as high as mid 20's. Brake dust seems a little more manageable on the GT4 but then again the M3 has gloss black wheels. The M3 gear lever is one of the best I've had in an M car but I would say it is more "comfortable" for frequent shifting than the GT4s rifle-bolt style shifter. Ingress and egress is noticeably easier in the M3. As for base sound systems, I think the GT4s may be a little better than the M3.
Overall, I would definitely prefer a road trip in the M3 over the GT4. They are both awesome cars though.
Thx for the comparison!
Old 08-23-2015, 11:05 PM
  #38
PistolPete
PistolPete's Avatar
Thank you for posting this!
For oil changes, I've purchased a few extra drain plugs and the Porsche filter wrench tool from Suncoast Parts. Be very careful with the oil drain plug, as you figured it's very easy to strip.
Old 08-24-2015, 12:49 AM
  #39
981GT4
981GT4's Avatar
Accel Junky,
Net time you have the front wheels off could you grab the part numbers for the lower brake duct.
I want to see how the part numbers compare to mine.
Old 08-24-2015, 01:13 AM
  #40
csbear
csbear's Avatar
Great write up Accel!
BTW, is the front air dam a little flexible? I noticed that it is more prone to flexing (compared to other cars I had) if I move the black front lip up/down. I assume that's normal as to accommodate any slight bending due to the low height of the car.
Old 08-24-2015, 03:12 AM
  #41
Crazy Eddie
Crazy Eddie's Avatar
Great Job
Both pictures and info !!
Thanks very much
Best of luck
Kind regards
Ed
ps Those wheel weighs are damn impressive ...
Unless one goes to a smaller wheel, I don't think your going to do much better
Old 08-24-2015, 05:01 AM
  #42
dy77
dy77's Avatar
Awesome videos of the exhaust sounds. Thank you so much!
Old 08-24-2015, 06:49 AM
  #43
Bardman
Bardman's Avatar
Took a couple of videos today:
The few times when you did the slow wind up to redline sounded awesome. And that's without any load. Can't wait to try it myself!
Old 08-24-2015, 08:37 AM
  #44
Brian 96C2
Brian 96C2's Avatar
Yes, thanks much for starting this thread. Very well done.
I have not taken my car to my shop where the other cars are stored, but I am wondering about getting my floor jack under the because it is so low. Is that photo showing front or rear point?
Old 08-24-2015, 09:20 AM
  #45
Accel Junky
Photo is of the rear side jack point. I use a low profile Harbor Freight racing jack and even with some plywood under it to protect the floor I had no trouble sliding right under.
Quick Reply: A Killer Croc - My Cayman GT4 Ownership Journal
