True GT4 weight and suspension info.
#31
#33
Weights:
Radio delete- 9 lbs
AC delete- 18
Small fuel tank- 20 (when both are full)
Lightweight buckets- 24
PCCB- 36 (est)
~107 lbs total.
So your 3117 becomes 3010. Fire extinguisher- 10? Trim, smokers package, etc another 10? 2990. Then Porsche weighs per DIN, meaning a 90% full tank. 1.6 gallons is another ~12, so we have ~2978. Call it a 20 lb gap. If the lithium battery was allowed for the measurement then we're more than there (30 lbs). Not sure what the tolerance is on the DIN standard, but realize that Porsche quotes weight for the lightest possible configuration.
#36
Belts and a roll bar will add as well.
#37
I would say you will not find a lighter car than the one Porsche gave sport auto For ring lap. This car is small 54l tank, delete klima, delete stereo, and its no clubsport pack, but its bucket seats and ceramic brakes. Hard to find them gt4 lighter than that i guess. Its 1378,5kg full tank fuel. My car is 1430kg full tank fuel. This is without driver in car!
#38
#40
#41
I don't think that car was such an extreme stripper. From the pics it looks like it did have the standard AC and Radio/PCM. Also Sport chrono and even leather. So the weight saving would only be from PCCB and buckets (~60lbs). Plus probably more fuel weight if they tested with either 90% or full tank (of the smaller tank) vs your half bigger tank.
#42
#43
Checked the strut mount to see how much adjustment is left with -1.5. as you can see its almost maxed out . i dont think you can get much more than -1.6 without adding shims. i may try a track day with the -1.5 and see how the tires look?
#44
he has the headlight nipples. This means extra large washer bottle to the tune of an additional 6 kg or 13 lbs. First thing i do when i get the car is to drain it to the minimum level.
#45
not to mention the PDLS mechanics - steering and leveling.
