GT4 - Unlocking the Power Potential!
#812
Basic Sponsor
To update the thread, i took the car down to Palm Beach International Raceway and ran it hard for 2 days straight of on-track activity. This was not your typical 30 minute run group 4 times a day setup but instead, non-stop on track activity in some rather hot and humid temps. The car's ability to make peak torque at 3500 RPM makes it awesome when you want to leave it in 3rd gear in the slow carousels that are too busy for 2nd gear downshifts. Everything was perfect...i did 3 laps during the hottest time of the day just to see what lap time i could run and i did a 1:25.8 which is on par with some of our race car laps that were turned when temps were cooler. the car has A TON of potential and with race mufflers, some lightweight oil and some race gas, there's plenty left on the table. no issues with the tuning; no issues with the behavior. Everyone came up and inquired about the exhaust setup once they heard the sound.
LINK BELOW TO AWESOME SOUND: https://www.instagram.com/p/BJivFvTD...bgbmotorsports
Thank you for your patience. Is there something that we failed to send to you? Or are you just waiting for more updates to the thread! Sorry...it's been a while since I've updated anything.
I have not had any issues whatsoever with unanticipated CELs, hung throttles or any weirdness. As it sits, there is 1 group in the world that can put 991 X51/GTS mapping in a 981 ECU. In the beginning i got heavily scrutinized due to the cost and the need to remove ECUs and have them cloned. I however have still maintained my relationship with this group in Germany who could do this for you BUT we won't be able to make changes once completed. I could however ask them to do this work for you if you wanted because without it, there is no TC, ESC, ABS, cruise control, etc. and the transmission temps and cluster behave oddly. i was able to turn a lot of these messages off on my own car but i won't release a car to a customer without this stuff functioning so as this point, your only option is to get them to do a custom mapping for you in Germany.
Just a few thoughts in response to that awesome "stage II" dyno on the previous page.
1. I've noticed from reading others' experiences that running aftermarket ecu tuning has had a few teething issues (CELs, hung throttle) and that, conversely, using the GTS map on the GT4 makes it run well, but some of the other features don't work (PASM/TC, I think). If I were to upgrade my car, I'd prefer a solution that uses the factory GTS map if someone could get everything else to work, over using aftermarket tuning. I don't mind if I get 10 less hp with the GTS map compared to something like COBB, I'd prefer the factory GTS tuning.
2. It still seems hard to get apples to apples hp gains from headers, however, perhaps roughly it's a 5-10 hp gain from sport catted headers, and 20 from "race" headers. I think I'd prefer to leave the headers stock because I'd need cats 10 hp might not be worth it.
So, down the line, if I were to upgrade, I'd like "82mm Throttle Body, 991 GTS/X51 Power Kit (Intake Manifold, Ported Cylinder Heads & Intake Cams) with a GTS map" which appears like it would give 50-54 hp at the wheels because the previous page of this thread shows a 74 hp gain at the wheels with the above AND long tube headers. Without long tube headers, 440-445 hp at the crank would be plenty![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
#813
So everything plays nice? For instance, when the sport button is pressed, does the cooling change like in the stock car (and the temps go down from about 235 to about 215)?
#814
Reminds me of trying to make OS X work on hardware that Apple didn't produce, many workarounds were needed, but it was fun consolidating everyone’s contributions;
http://www.insanelymac.com/forum/top...modifications/
#815
#816
#817
I am confused. Are you saying that we would need the new ECU if we want to preserve TC, ESC, ABS, etc? If that's the case, why would someone go through the hassle and expense of the X51 option with the new ECU instead of just doing the 3.99 stroker kit? Yes, I understand you're tearing your engine apart with the stroker kit and will not be able to put it back to stock. But is someone spending $25K on the X51 package (inclusive of the new ECU) actually thinking they might return their car to stock??
#818
Originally Posted by d00d
Installing X51 on the GT4 doesn't require the 991 GTS map, but if one wanted to use it, those are the issues if it's not tuned.
2016 white/black GT4;
https://rennlist.com/forums/gt4/9321...e-journal.html
2008 white/amaretto S8
#819
Location: On a pygmy pony over by the dental floss bush
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
#820
GMG installed Cargraphic sport headers from the group buy for me last week and did a full proper alignment set up with a lot of new suspension pieces. Car sounds fantastic and handles like it is on rails - their set up was absolutely awesome!
The sound going slow in regular mode is essentially the same as stock. Once in sport mode and on it there is a higher pitch to the note - not as deep. Their is noticeably less burble and pop on throttle lift off then stock - still there, just not as pronounced. Only one 70 mile drive so far but all in all very happy with the upgrade and feel for the street the sport headers are the ideal choice!
Now I need 82mm throttle body, IPD plenum and a tune! Coming soon I am sure!
Love this car even more than before!
#821
Basic Sponsor
Good luck with that ECU transplant John.
Thanks Dood...i have made my car work flawlessly without it with the GT4 firmware because it's a lot easier than trying to execute what is a task of rather high difficulty. It's the equivalent of just what you said, BUT, having collaborated with the folks in Germany, it not only works and is not only available, it's on an existing 981 X51 PDK conversions we completed last year.
#822
Basic Sponsor
The 4.0L Stage III Boxster Spyder is born! Technically it's missing the Stage II "Cup" Muffler system from Cargraphic but we didn't want to go too loud nor did the owner want to give up the PSE.
#823
Would you mind listing the suspension components you/they did and alignment results?
#824
https://www.instagram.com/p/BJvoWtyjFDe/
#825
Here are some photos of alignment and parts used and a shot of the headers.
