Sponsored by: APR
Upcoming Cayman GT4
Old 02-13-2015, 02:54 PM
  #526
beanboy
beanboy's Avatar
Anyone have any idea how the ride height of the GT4 is gonna compare to say, a Ferrari 360 (one of my other cars)?
The ride height is my only concern about tooling around town in the GT4. I really hope it's not much lower than a stock 360...
Parker
Old 02-13-2015, 02:59 PM
  #527
GrantG
GrantG's Avatar
Received 4,954 Likes on 2,806 Posts
Originally Posted by GTgears
They never stopped using Getrag in the 6spds. All Caymans and Boxsters get them. And I've never seen a Drexler LSD in a Porsche. GKN has been their supplier since 1996.
Thanks, Matt. I thought Aisin made all the 6spd manual gearboxes in the 997 Carreras though, no?
Old 02-13-2015, 03:05 PM
  #528
GTgears
GTgears's Avatar
I'm just talking about midengine. 997 is Aisin as is 7spd.
Old 02-13-2015, 03:27 PM
  #529
Beantown Kman
Beantown Kman's Avatar
Beanboy-- the GT4 ride height is adjustable. Raising the car would surely deviate from factory specs but I don't see why it couldn't be done if needed.
Old 02-13-2015, 03:31 PM
  #530
shaytun
shaytun's Avatar
Originally Posted by beanboy
Are you guys speccing CF trim on your cars or just sticking with aluminum?
I can't decide.
Parker
CF for me. I think it looks appropriate in a "GT" car. All trims look great though.
Old 02-13-2015, 03:32 PM
  #531
shaytun
shaytun's Avatar
When you say it's adjustable, what do you mean. There's no axle lift obviously as far as I know. Or do you mean you can change it aftermarket?
Old 02-13-2015, 03:51 PM
  #532
DeerHunter
DeerHunter's Avatar
The struts are essentially "coil-overs", with threaded collars to allow corner-weighting and some height adjustment. It remains to be seen just how much adjustment there is and whether it will lead to issues with respect to shock travel. Regardless, any ride height changes will require significant effort and an alignment afterwards.
Old 02-13-2015, 04:14 PM
  #533
beanboy
beanboy's Avatar
I'm not interested in messing up Porsches heavily tuned suspension by manually raising it
So that being said, isn't it 18mm lower than a standard cayman? Or is it 30mm? If I know that I can calculate the height...
Parker
Old 02-13-2015, 04:23 PM
  #534
arena-RTR
arena-RTR's Avatar
Parker
It is adjustable, but I would expect it to be exactly the same as the GT3, considering they share the same front suspension. I believe the GT3's front clearance is 103mm
Old 02-13-2015, 04:24 PM
  #535
beanboy
beanboy's Avatar
Thank you
Old 02-13-2015, 06:39 PM
  #536
Ferrarisimo
Ferrarisimo's Avatar
Parker
It's 30mm lower than a standard Cayman.
Old 02-13-2015, 07:33 PM
  #537
sl951
sl951's Avatar
I wonder how much 'tire' you can fit on it (contact patch)?
Old 02-13-2015, 10:48 PM
  #538
spyder fan
spyder fan's Avatar
Beanboy, It will be lower. I also have a 360 and it is definitely higher than the Boxster or Cayman. The GT4 has PASM so it should be ok at the highest setting.
Old 02-13-2015, 11:31 PM
  #539
AMGsound
AMGsound's Avatar
^as far as i understand PASM, it doesnt raise or lower the car at different settings, my understanding is that the shocks become harder with sport button pressed vs normal. Yes, the ride height is different with PASM vs a non-PASM car, but it's ALWAYS, no matter the setting, different/lower.
The GT4 will always be 30mm lower than normal Cayman, 30mm lower when riding in normal mode, 30mm lower when riding in sport mode.
Thats why you can opt for sport suspension on Cayman S and GTS, where it's 20mm lower than "stock", always is, and always hard/sport, no "normal" mode. Some say it's even harsh.
Good thing GT4 comes with PASM for adjustability of ride "smoothness"!!!
Old 02-14-2015, 08:27 PM
  #540
JSF101
JSF101's Avatar
front suspension
Quick Reply: Upcoming Cayman GT4
