Lancia Delta Integrale HF 16
#46
It’s been a slow process with the engine build. World wide supply chain being what it is, really slowed the process up, but we are finally making some advances. The head has been machined / ported, drilled and taped for ARP 12mm bolts, installed bronze valve guides, refaced seat 3 angle, lapped valves etc.
#48
The turbo on my car should be a T4, but is actually a T3, which came on the later Evo cars. The T3 was a improvement on reducing some of the turbo lag. My T3 was rebuilt and modified for the increase in HP. The following was done.
Original turbo has been upgraded by fitting a Garrett GTW Ball bearing core assembly.
Compressor cover and turbine housing have been CNC re-profiled to perfectly match the larger turbine and compressor wheel.
Std oil and water connections are maintained.
Compressor wheel spec: 48.55mm inducer, 69mm exducer, billet 7/7 blades with extended tips
Turbine wheel spec: Garrett GTW34, inducer 65mm, exducer 57mm
Turbine seal has been upgraded to a Total seal stagger gap piston ring
Actuator upgraded to Turbosmart GenV Twin port with
Ported wastegate
Ported wastegate
rutthenut (08-26-2022)
The following 3 users liked this post by Blagave:
#53
#54
#55
#57
#58
Company is 'Auto Integrale' in the UK, who also sell quality Integrales (as Auto Moda).
https://automoda.net/inventory/
I think they've done one or two builds for the USA already.
They run a car on demo events, including Rally Legends in Europe and know their stuff.
Just looked and they do have an older 8v track car that could be a bit of fun.
https://www.carandclassic.com/user/ccts5861
The following 2 users liked this post by Blagave:
ekranoplan (05-04-2023),
LimeyBoy (02-10-2023)
