Sponsored By:
Sponsored By:
New PB Drilled Rotors on 958 CTTS
Old 04-16-2018, 02:47 PM
Nine1won
Nine1won's Avatar
Default New PB Drilled Rotors on 958 CTTS
Thought I'd share with you the new drilled rotors I installed from PB Brakes this weekend. They look and fit great! Love the drilled look with black wheels. Thanks PB!
Marc in AK (10-27-2019)
Old 04-16-2018, 03:39 PM
deilenberger
deilenberger's Avatar
Received 1,160 Likes on 767 Posts
Nice look - nice picture - wrong forum. I'll move it to the 958 subforum for'ya.. hang on..
Old 04-16-2018, 04:28 PM
Nine1won
Nine1won's Avatar
Thanks! Didn't realize there were sub-forums in the Cayenne area!
Old 04-16-2018, 08:39 PM
fatmatt0116
fatmatt0116's Avatar
Nice. First set of aftermarket rotors for the ctts I've seen. Good to finally have an alternative option to OEM. What was the price for F&R? Functionality good?
Old 04-17-2018, 07:59 AM
Petza914
Petza914's Avatar
Received 6,736 Likes on 4,286 Posts
So are those 380mm x 38mm?
Old 04-17-2018, 12:08 PM
DrBillyD
DrBillyD's Avatar
Looked at PB web site (pbbrakes.com) and have various rotor sizes listed (405mm, 380mm, and others) but not 390mm, which is what I thought OEM front rotor size is on '14 CTTS.
Did you use 380mm with some modified hardware to fit stock calipers?
Old 04-17-2018, 12:57 PM
deilenberger
Or are they 405mm? Which I believe may be able to be used with the 390 caliper...
Old 04-17-2018, 02:38 PM
Nine1won
Nine1won's Avatar
I had them custom make the correct size in 390mm front and 360mm rear. They fit perfect and seem to work great. It was pricy though at around $1800 I think for all four. Quality seems higher than OEM.
Old 04-17-2018, 05:14 PM
chiapet15
chiapet15's Avatar
Are you able to share info for the contact you worked with to customize the sizing and place the order? I have emailed pb brakes via the email address on their website and haven't gotten a response yet.
Old 04-18-2018, 09:21 AM
kennyt
kennyt's Avatar
What brake pads did you use to accommodate the new rotors?
Old 04-18-2018, 11:16 AM
Nine1won
Nine1won's Avatar
I worked with Dan Newton - the PB Brakes Sales Director at email: contact@pbbrakes.com. Phone number +886(0)972985600. It took a couple of wheels to custom make.
Since they are stock size rotors, I'm using new OEM pads.
Old 06-03-2019, 11:08 PM
NWturbo
NWturbo's Avatar
Hi, sorry to revive an old thread
I am about to do the same order as you for my 958 Cayenne Turbo.
Have you been happy with the PB rotors so far and would you buy from them again when the time comes for new rotors.
Thanks!!!
Old 06-07-2019, 02:33 AM
RAudi Driver
RAudi Driver's Avatar
Received 2,988 Likes on 1,772 Posts
$1,800 for four rotors. Big pass.
Old 06-08-2019, 12:15 AM
deilenberger
Ed, absolutely - I got a much better deal recently (and they're working wonderfully... look much better too..) Another 1,000 miles and I'll have them home.
Old 06-08-2019, 01:18 PM
911Spdstr
911Spdstr's Avatar
What’s the new / better price?
Quick Reply: New PB Drilled Rotors on 958 CTTS
