Transfer Case Failure
#61
Hi guys - first post here on Rennlist.
Our 2014 958.1 base model that we've had for about 7 years has been an excellent car - that's coming from my 20 years as a certified Audi technician in the bay area. Porsche has a 10 year warranty on the TC on this car (I also have a 2015 958.2 CS that only has an (expired) 8 year warranty) so i took it to the dealer and with some shifting concerns and they replaced the TC for free. Extremely happy Porsche customer here.
I did replace the TC fluid in the 958.2 and developed some 4WD faults that I figured out needed an adaptation in the transmission computer - no more warning after 15mph (this fault would erase on a key cycle but return every time).
Thanks to this forum for the knowledge.
#62
FWIW - My 2016 Cayenne Turbo S is on its third transfer case with 90k on it.
My 2017 Cayenne GTS is on its second transfer case with 58k on it.
My 2009 Cayenne Turbo is on its original transfer case with 83k on it.
The 2009 Turbo is the real beast of burden of the three and I frequently drive it in deep snow and off road conditions. It is an absolute monster when off-roading and absolutely eclipses the newer Cayennes performance level. I love all three of them though and have done a DE with the 2016 Turbo S and it is shockingly fast for an SUV.
My Porsche service manager has been quite helpful whenever I've had a problem. Good relationships with service managers are critical when you own over a dozen Porsches.
#63
I recently bought a 2011 Cayenne S, which has 193k kilometers (approx. 120k miles) and after carefully checking the entire history, it has never had its Transer Case or oil changed. This week I will change the oil to Ravenoil to flush out what I find there, and after another few hundred kilometers I will fill it with OE Porsche. As of today, the gearbox still works with no issue, which is a phenomenon for me considering this mileage.
#64
Update on my transfer case all wheel drive warning - it returned after about 500 miles and one more adaptation locked up the computer with clutch max wear limit faults 00117 & 00114 that wont adapt or erase. I've sourced a rebuilt TC from Awd.tech and ill replace it myself when it arrives - they gave me a price that made rebuilding it myself not worth the work. 150,000 miles on the car but i don't know if it is the original TC.
#65
If it were my car, I would not change out the Transfer Case fluid. Instead, next time you have it at the dealer or an independent/friend that has a PIWIS, I would ask what the wear parameter is. From AllDataDIY for my 2011, "During servicing, the oil for the transfer gear must only be changed if the wear parameter in the transfer gear control unit is > 75 %. -> 033500 Diagnostic maintenance: diagnostic system and maintenance inter."
Can you grab the part number off of the transfer case? Should be a stamped number on the bottom of the case closest to the transmission and hopefully a paper one still attached at the top of the case. Should begin with 958....
#66
OP,
#67
I understand. Been there, done that. If you have not found this thread, it should help. Especially to not crack the case at one or both fill/drain plugs. https://rennlist.com/forums/diy-caye...-change-2.html . You will note that the last post is mine when I changed the fluid, I was feeling snaps and pops. Ended up with a replacement transfer case 6 months later because the fluid change made no difference in my case.
#68
Update: Rebuilt transfer case came very quickly from AWD.Tech and I installed it on the driveway (toughest part was trying to pry off the drive shafts with no room / clearance because of the ground). I was able to code the new module using my Thinktool Pro scanner (No need for PIWIS). I have about 1000 miles on the rebuilt case and it's driving fie - No more "AWD fault" displayed on the instrument cluster.
#69
#70
It's possible that it wasn't required I guess. I selected control module replacement and it seemed to code it. Stated ' coding performed ' but I didn't see if it cleared the code before driving. I replaced the unit, used the scanner to code the module and then went for a road test.
#72
#73
I’m a bit concerned I might have this issue but I can’t pinpoint it. Porsche says it’s good, but there are times I hear a grinding sound when I’m driving. It’s not the brakes. I think it’s either the TC or Differential. I did change the fluids in both a couple of weeks ago. Is there a warranty on these for a 2017? It has 109K miles on it
#74
The dealer has PAG approved diagnostic procedures so keep bugging the dealer. I do not recommend changing the transfer case fluid at this point.
Double check the weight and GL type of differential fluids you used. If both diffs are typical, then 75W-90 GL4 or GL5 is all you need. If the rear diff is limited slip, then it will need 75W-90 LS GL5. I have regular diffs and run the 75W-90 GL5 Synthetic.
#75
