Sponsored By:
Sponsored By:
2014 GTS - high mileage experience
Old 11-11-2023, 06:55 PM
  #46
Ryancruzsilvino
8th Gear
Ryancruzsilvino's Avatar
Thanks for updating us and continuing the journey! Super helpful as i am in the market for a 958 GTS also!
Old 03-20-2024, 09:01 PM
  #47
Jc27
Jc27's Avatar
Default New update - another service at 130k miles
I'm here to update everyone on the '14 GTS -
Took it in for the annual service. I had noticed that it wasn't starting like it should be, seemed a little weak at times. Figured it needed a new battery since none of my records showed that the previous owner had the battery replaced, nor had I replaced the battery in my four years of ownership. I was also getting the PSM error code 2-3 times in the last 2 months. I didn't run my code reader since a quick google search said it could be a dying battery. Anyway, here is what was done and found during the service -
mileage: 130k
- oil change ($264)
- spark plugs (these were due to be changed)
- ignition coils (there was one bad ignition coil causing the PSM error code. I told them to put all new coils in, I figured if one went bad, the others would follow soon after) ($1200 for spark plugs and coils)
- replaced battery (they said from what they could tell it was the original battery, which would make it 10yrs old, it wasn't charging properly. If the battery was 10yrs old, that's pretty amazing for batteries and cars these days) ($565)
It was a rather expensive service at $2.4k (including state inspection ($90) and $130 total to diagnose the battery and error code), but all in all I would say typical normal wear and tear. I should be good for another 40k-60k miles before replacing spark plugs or coils again. I'm still keeping my fingers crossed that the air suspension, transmission, transfer case, and coolant tube don't give me problems anytime soon.
I'm still loving this GTS and hoping to get another 3-5 yrs out of it!
The following 4 users liked this post by Jc27:
chassis (04-01-2024), max911 (03-20-2024), s65e90 (03-20-2024), will_atl (03-23-2024)
Old 03-20-2024, 09:47 PM
  #48
s65e90
s65e90's Avatar
Nice updates. Seems like most gts and turbos have high miles with relatively nothing but maintenance.
Old 03-20-2024, 10:48 PM
  #49
luciano136
luciano136's Avatar
mileage: 130k
- oil change ($264)
Were those the original coils at 130k mi? I'm at 60k - contemplating changing them since I'm not sure if they were ever replaced; PO had a large service done at the dealer, but of course the dealer won't tell me what was done.
Old 03-22-2024, 09:12 AM
  #50
Jc27
Jc27's Avatar
The service records I have don't indicate that the previous owner replaced the coils, so it's possible those were original.
luciano136 (03-23-2024)
Old 03-22-2024, 11:58 PM
  #51
leftlane
leftlane's Avatar
I’m on original coils at 153k miles. No issues - I do follow the manual and get the plugs replaced every 40k. Car has been pretty much rock solid.
The following 2 users liked this post by leftlane:
Jc27 (03-23-2024), luciano136 (03-23-2024)
Old 03-23-2024, 02:51 PM
  #52
luciano136
luciano136's Avatar
Oh, wow! Maybe overkill to replace them then?
Old 03-23-2024, 02:56 PM
  #53
Sam_M
Sam_M's Avatar
Here's a data point:
My 13' GTS started having ignition coil issues last year at 152K. I replaced them all.
The following 2 users liked this post by Sam_M:
chassis (04-01-2024), luciano136 (03-23-2024)
Old 03-23-2024, 03:15 PM
  #54
luciano136
luciano136's Avatar
Maybe I'll just do the plugs in that case. Replace coils at 100k.
Old 03-24-2024, 12:42 AM
  #55
leftlane
leftlane's Avatar
I’ll replace if there ends up being an issue. Otherwise I’ll spend the money elsewhere 😁
Old 03-24-2024, 02:37 PM
  #56
luciano136
luciano136's Avatar
Ha! Totally get that. Almost all my driving is longer distance, so I like to avoid any issues if possible
Old 03-27-2024, 12:46 PM
  #57
bdronsick
bdronsick's Avatar
These are indeed unbelievably well built vehicles.
Old 04-01-2024, 09:56 PM
  #58
chassis
chassis's Avatar
Received 1,249 Likes on 923 Posts
mileage: 130k
- oil change ($264)
Price quite reasonable. Indy shop or dealer?
Old 04-01-2024, 09:57 PM
  #59
chassis
chassis's Avatar
Replacing coils and plugs always makes a difference. Both are consumable parts that have finite useful lives.
Old 04-01-2024, 10:22 PM
  #60
Jc27
Jc27's Avatar
Indy shop
Quick Reply: 2014 GTS - high mileage experience
