Sponsored By:
Sponsored By:
Cayenne Coding - The Ultimate Guide & Discussion
Old Oct 14, 2020 | 12:33 AM
  #601
volcanogts's Avatar
volcanogts
Looks like the activation code for the heated steering wheel is vin specific.
I have located a few online companies that are able to generate the activation codes by the VIN. They state it will only work with a PIWIS Tester 2, I am using my Launch X431 Pro S Mini, and have asked if it might work.
I will keep you all updated.
Old Oct 14, 2020 | 12:50 AM
  #602
siberian's Avatar
siberian
Yes, please keep us posted. Why it needs to be activated based on a VIN...?
siberian
Old Oct 14, 2020 | 02:26 AM
  #603
rainer's Avatar
rainer
why? Because Porsche designed it that way..
there‘s also a VIN specific code for some other functions like multifunction steering wheel or several functions in PCM (voice control, logbook, bluetooth) in case the car does not come with those options.
I did the retrofit last year with 2 cars, works perfect.
you need the activation code of course and it needs to be activated w/ a Piwis 2 or 3. the codes are only available on the grey market. I think there‘s 2 or 3 sources out there, all pointing to Russia or Ukraine.
Codes sell for around 100 bucks.
Coding of the function in dash cluster of course as well.
siberian
Old Oct 14, 2020 | 03:03 AM
  #604
siberian's Avatar
siberian
They spend all that time and cash to **** folks off and then some guy in Odessa or Murmansk turns a profit and they look like clowns and all for a heated steering wheel...Eine echte Schweinerei!
siberian
Old Oct 14, 2020 | 09:17 AM
  #605
rainer's Avatar
rainer
Well, the original idea for some of the options is to make it impossible to retrofit.. and for some to make money thru dealer retrofits indeed.
heated steering wheel is in the group of „no code - not even for money“ , hence only possible thru grey code
market from the lucky guy who seems to have a copy of the code generator..
Old Oct 14, 2020 | 09:25 AM
  #606
volcanogts's Avatar
volcanogts
I think I might be able to obtain the code at this point but I’m not sure if I can only do it with a piwis 2 or if I could use my Launch setup. I can get to a screen that asks for the activation code, I assume it’s just a password and once entered unlocks the option? Nothing has to be downloaded and installed?
Old Oct 14, 2020 | 10:21 AM
  #607
rainer's Avatar
rainer
That looks great indeed, 16-digit HEX is exactly what needs to be entered.
nothing to download or install in this case. Just enter the code and you‘re good (plus normal coding of option of course).
There are instances which need an install (logbook for example) in PCM3.1, but not for steering wheel options.
I‘m starting to get impressed by the launch.. all other tools except Piwis don‘t get you very far indeed with those topics..
Old Oct 14, 2020 | 11:17 AM
  #608
volcanogts's Avatar
volcanogts
Yes I am impressed as well. Returned an expensive autel unit for this and it had been great. We own a small used car lot and it has been great for vehicle specific coding across multiple makes. It updates regularly.
Old Oct 14, 2020 | 12:31 PM
  #609
siberian's Avatar
siberian
Great buy the Launch! Any leads on a code generator? Might be useful for other options as well. Hmmm, will try and contact some friends in former Eastern countries...
siberian
Old Oct 14, 2020 | 12:50 PM
  #610
volcanogts's Avatar
volcanogts
I contacted 3 so far. One I have heard back from and waiting on another response, one seemed very sketchy and wanted $300, and waiting on a reaponse from the third. Seems like the going rate is $100-$125 for the codes. One place says they generate all codes for your vin and send them to you. My new stalk has voice control so that might be beneficial and also thinking of changing my clock with broken second hand to a red compass.
I will let everyone know if I hear back and if it works out.
Old Oct 14, 2020 | 12:54 PM
  #611
siberian's Avatar
siberian
I have reached out to my contact, I will depending on answer get back to you or PM you. I asked not only for sources as a one time buy but also to purschase a decoder. Might be useful and depending on cost we could do a group effort (buy).
siberian
Old Oct 14, 2020 | 01:51 PM
  #612
rainer's Avatar
rainer
I doubt someone will sell the decoder as it‘s a cash machine..
I know that at least code-porsche site worked in 2 cases reliably. Also for someone who was given a wrong code and lost money, trying another source.
I have all codes for my own car as well.
Little strange - it creates codes for a PCM 3.1, even for PCM4 cars. I haben‘t figured out if they are of any use - the enabling of functions in a PCM4 works different than in PCM3.x versions... and not just by entering a 16-digit hex code
Old Oct 14, 2020 | 02:53 PM
  #613
twodollardoug's Avatar
twodollardoug
I'm confused about these "codes". What are they and what do you need them for?
Old Oct 14, 2020 | 03:10 PM
  #614
don16's Avatar
don16
Google "porsche activation code"
Lots of websites come up including this one:
https://www.code-porsche.com/
That one seems to accept PayPal(apparently) and if you use credit card then double protection against being scammed.
Old Oct 14, 2020 | 03:18 PM
  #615
volcanogts's Avatar
volcanogts
The code-porsche website is the one I was looking to use actually and I have not received a response yet.
