PCM 3.1 stuck in emergency update loop
#256
Thanks i did try that as well but got the same error at the same point in the upgrade, the always get the boot loop. luckily i kept the usb update with the 2 lines missing in the config so i can get back to the pcm booting up.
if a partion was bad or locked would the clonezila export of partion tables transfer a fault to the new drive ??
#257
sudo -s
sfdisk -d /dev/sdd | sfdisk /dev/sdb
would it copy the corruption as the way i read it it would just create the partitions, i did the above put the new drive in and still got the exact same copy error
sorry if i am being thick
#258
for my sanity can i clarify if i run on a drive that has corruption
sudo -s
sudo -s
#259
For those of you with a perfectly working PCM, I upgraded my HDD with a Samsung 870 EVO 250G SSD for $40. I used the Fideco hard drive cloning device for an additional $24 both from Amazon. You plug original HDD in bay 1 and new SSD in bay 2 and begin the sector-by-sector clone. No PC needed. It took about 45 min to clone and didnt fully remove the PCM from the Cayenne. Pretty straight forward. I wish the best of luck to those of you having boot loop issues. I hope that I averted much pain by preempting a drive failure.
PCM out 90 % but all cables and vents still attached.
2 bay cloning device. No PC or clone software needed. Original HDD in bay 1 and SSD in bay 2.
#260
Feels like a corrupt partition.. cloning wont help... Get a brand new ssd (dont reuse your current one ) and build the partition table from scratch - option 3 in post 24 that i made a while ago lists steps to create the partitions using clonezilla but you can use other tools too.. then plug the ssd in and run the update disk..hth..
tried doing the partition from scratch, My Linux is a bit rusty but nearly got there except the first partition started at 2048 not 63 and for the life of me I cannot work out how to re set it to 63
if i run sudo fdisk /dev/sdb
then press X i gt into expert mode but not sure what to do next
The actual partition in question is /dev/sdb1
I also get in red below the partition info when i run fdisk /L
Partition 2 does not start on physical sector boundary and so on for all the other partitions
see attached
any advise would be great
#261
Hi Karl
see attached
see attached
https://unix.stackexchange.com/quest.../112201#112201
#262
In the expert mode type m to get list of commands and b to change the beginning. More info here..
put it pack in the car and tried the update but still fails with a crc error on the .placeholder file of step3
i will try find a download for 4.74 and give that a go, if all fails think its time to change it for an aftermarket unit
#263
Thanks Karl for you advice that allowed me to get the drive looking as it should partition wise, checked it on my linux laptop and all looked ok
#264
PCM 3.1 stuck at .placeholder
Crc error is usuallly a bad source disk. Check out this post - maybe you can use this image .. https://rennlist.com/forums/audio-an...l#post19352732
My PCM is stuck in Emergency Mode even after the HDD has been cloned to an SSD and the latest update is that I have received a clone from an HDD from another car. Still stuck in EM and when I insert the DVD to upgrade from 4.73 to 4.76 the update gets stuck at the exact same place (see picture)
1) is it possible that the issue is not related to the disc?
2) do you know how I can get out of the EM?
I only have access to Mac but I have a relative who is great with computers and he has a good PC.
Regards from Sweden
#265
PCM 3.1 stuck in EM
Just some additional info to my previous post.
The problem with the PCM stuck in EM started initially when I tried to upgrade to 4.76 and the electricity broke the update off. If I only had known that I needed to have at least the ignition on…
#266
Hi Kari,
Regards from Sweden
Regards from Sweden
At first try to just copy your update DVD to USB completely without any modification and then use it instead of a disk. If it does not help then try to mod the .def file as described in #21
By the way could you please tell me does your PCM flash any lights inside when it does HDD access? I'm asking because mine also got stuck in Emergency mode and none of the recipes work. I suspect there's hardwsre issue with PATA/SATA interface. I'm sure there were orange HDD led flashing but now it does not... Please anyone confirm is there a HDD activity LED somewhere in PCM3.1?
#267
Hi Kari,
Regards from Sweden
Regards from Sweden
#268
Find and download a file called “pcm_20150721.iso”
There’s a google drive link in one of the PCM threads here, you can use that one. Search with the filename on Google it’s pretty easy to find.
Format an 8 gig USB stick with FAT32. Older the drive the better. Also try not to go above 32GB if you can. The usb updater is finicky. (If you’re on a Mac, use Disk Utility > Partition and choose MBR as partition table type. I don’t know about Windows but the regular format function should do ‘er.)
Mount the ISO image, and drag & drop all files to your newly formatted USB stick.
Plug the thing into the center console USB and it should start updating.
You can also burn the iso onto a DVD and update with that but only Verbatim brand DVD-R disks burned at 2x will consistently be readable. Any other disk brand or faster burnt disks always cause trouble at some point during the update.
Ha det så bra, DM mig om du får någon problem. Lycka till.
#269
For those with Macs: If you're stuck in the emergency update loop, where it's failing at 99% right before the end: I had the bad sectors issue when trying to do an offline clone. Was creating a bootable usb to load CloneZilla (unsuccessfully) and stumbled upon balenaEtcher for mac. Anyways the "clone drive" function on balenaEtcher fails at 2% (wait for the retry prompt, and hit cancel) but successfully copies over the partition structures of the original drive. This avoids having to run CloneZilla at all - close and relaunch Disk Utility to ensure the partitions match the original drive and you should be good to go.
#270
Hi guys, I’m new here and new to Porsche as well. I have a 2014 Boxster 981 with PCM and Navi… I’ve the same issue here or maybe sort of.. checked all the options you mentioned but still not able to get my unit fully back to work. Just tuner and Aux.
After my last attempt to install the latest so I notices I have possibly some problem with IOC and APP.. as the SWID results to be invalid…did I completely break my unit? Any help would be appreciated…
