CarPlay Retrofit in PCM 3.1 Cayenne 2013 ( With Pictures )
#1486
Basic Sponsor
Thank you for your video. I was just thinking that the function of the internal boards could be absolutely identical in JoyeAuto and Mr12Volt units (Isudar, having no external box, is different). Basically the board adopts video signal sent from external units for PCM. The port on both external boxes is FAKRA, the name of the port in both cases is LCD OUT. So I thought that for the people currently with JoyeAuto the switch to Mr12Volt wouldn't probably even require taking PCM out of the car completely as there is probably no need to open it to swap the boards. But may be I am wrong.
Modernize your P-Car w/ Mr12Volt. Apple Carplay and Android Auto with superior audio quality, features, and support. Reach out for specials! Torque.Acs@gmail.com or Roman (267) 317-8229
Our website is now LIVE! please visit us at www.ACSByRoman.com
COUPON CODE "toys" FOR FREE INSTALL KIT!
On site install is available in the Philadelphia PA area as is Global shipping!
CLICK HERE JOIN OUR FACEBOOK GROUP
#1487
#1488
#1489
If I am not using the dvd/cd player, is there any reason at all to reinstall it and the ribbon cable for it?
[edit]Meh, tried with and without to no avail. I just get a flashing red light on the Asudar and no video, period. (‘14 S)
Last edited by scottmcdaniel; 06-23-2024 at 12:08 AM. Reason: Changed to a dumb question
vwbrd (06-24-2024)
#1491
Going down the CarPlay rabbit hole on my 2011 Cayenne 958. I have been researching for the past few days and I still have some questions that i'm trying to better understand. Hope somebody here can assist with the following:
1. Is the Mr12volt the only unit on the market to have the MOST ring connection instead of using the car analog "AUX"?
2. Do I need the external Microphone for the Mr12Volt unit? If so, what does it actually do? - I'm trying to avoid having to connect to two different devices to stream music and answer calls. Ideally I'd just connect to Mr12Volt and it would allow me to use the internal mic already in the car.
3. How big is the audio quality difference between a chinese unit vs the Mr12Volt model? I have the base (not Bose) speaker system in my car and I'm wondering if you'd be able to hear the difference.
#1492
Basic Sponsor
1) yes, no one has been able to copy the mr12volt system.
2) the current model (Grey box) uses intergrated mic, the the older (blue box) has additional mic which was used only to speak to siri. Model is discontinued.
3) yes of the is a quality difference. Even in base radio
Every time you convert audio from native digital to analog you lose quality. With base radio especially I'd want to keep every ounce of quality I have.
Here is the kit correct kit (Grey) you need. Scroll down the page for the free bundle.
https://acsbyroman.com/product/porsc...st-pcm-3-1-mm/
[SIG] [/SIG]
wrscott (07-12-2024)
