Oil burn... Or lack thereof.
Old 03-15-2015 | 01:32 PM
Matt O.'s Avatar
Matt O.
Lifetime Member
Default Oil burn... Or lack thereof.
I have read lots of posts about burning oil in the Cayenne. I am at 9,000 miles since the previous change, and just looked at the level on the dipstick and it is near max, where it was upon filling.
Have I just gotten very lucky that it doesn't burn any noticeable amount of oil? Not that I'm complaining I just was expecting to see less oil when I checked it.
Old 03-15-2015 | 01:50 PM
CAVU's Avatar
CAVU
My "normal" consumption when comparing oil level at oil change against future oil measurements (oil AND normal accumulations of moisture and unburned fuel) appears to be near zero. That was mostly a highway 5000 mile trip. So I am certain that some oil is being consumed because I am certain that small amounts of moisture and unburned fuel are being captured in the oil....as designed. So my point for you to consider is that when performing comparisons, consider the added moisture and unburned fuel AND always try to measure with the oil at about the same temps, same parking spot and same amount of time after shutdown.
When I tow a trailer at 70mph and in the mountains over a 600 mile trip I will see a one bar drop. I don't have a dipstick. I don't see higher oil temps.
I have about 12,000 miles on this car which I purchased with 37,000 miles. So I have some data, but not alot...yet
Old 03-15-2015 | 02:01 PM
hahnmgh63's Avatar
hahnmgh63
I think the Turbos are the ones that tend to burn more oil. Which isn't really unusual for some Turbo cars.
Old 03-15-2015 | 07:55 PM
deilenberger's Avatar
deilenberger
My '06 consumes no oil. Zilch. Nada. The level never changes on the dipstick.
Old 03-15-2015 | 10:34 PM
SteveFromMN's Avatar
SteveFromMN
So far my 2015 S uses no oil at 2500 mi. I run it like I stole it all the time.
Old 03-16-2015 | 11:35 AM
TomF's Avatar
TomF
TTs are thirsty in more ways than one. My '08 TT consumes about a quart every 800-1000 miles. Porsche states that 1L per 600 miles is normal.
Cheers,
TomF
Old 03-16-2015 | 05:39 PM
ciscorp's Avatar
ciscorp
How often do you change your oil & filter? My 4.5 L doesn't burn any oil that I notice.
Old 03-17-2015 | 01:05 AM
skiahh's Avatar
skiahh
Mine burns about a gallon every 30 miles.
Old 03-17-2015 | 01:22 AM
SteveFromMN
I only put about 4000 miles a year so I change once a year just before winter.
Old 03-17-2015 | 01:34 AM
Designer's Avatar
Designer
Nope. Never add oil to my '06S.
Old 03-17-2015 | 01:46 AM
AGARubberDuck's Avatar
AGARubberDuck
I get about 1500mi/qt. It's been the same as long as I've owned it. 04tt 150k on the odo.
Old 03-17-2015 | 03:17 PM
porschefan931's Avatar
porschefan931
I use about a liter every 1200-1400km and i note most 'S' owners report no oil usage. I'm pretty sure the turbos are sitting there drinking the stuff.
Old 03-18-2015 | 12:57 AM
Kevin M.'s Avatar
Kevin M.
Yep my TT drinks a quart every 500 miles and the S burns a quart every 10k
Old 03-18-2015 | 03:19 AM
gbratk's Avatar
gbratk
I change oil every 12000km, and I have never add any oil between oil changes.
Quick Reply: Oil burn... Or lack thereof.
