Would you guys condsider V8 cayennes timebombs?
Old 12-03-2013, 11:30 AM
cayenneS2004
cayenneS2004's Avatar
Default Would you guys condsider V8 cayennes timebombs?
Would you guys condsider V8 cayennes timebombs? Does every v8 cayenne 2003 and up get cylinder wall damage eventually? Thank you
Old 12-03-2013, 12:03 PM
mcbit
mcbit's Avatar
No!
Old 12-03-2013, 12:04 PM
jumper5836
jumper5836's Avatar
lol
Old 12-03-2013, 12:07 PM
DWPC
DWPC's Avatar
I've been on this forum for a year and don't recall reading a post that actually reports this happening. Several threads on rumors and fears, but the actual occurrence seems low to rare.
Old 12-03-2013, 12:16 PM
mcbit
mcbit's Avatar
As I wrote in another thread there are upwards of 300,000 M48 engines out there and I cannot find more than about 15 unique posts on the internet worldwide from people have had this problem.
Apparently it is much more common in cold climates and XR4Tim reported a failure rate of around 20% whilst working in a dealership in Alaska. My Porsche specialist indy has seen none.
Old 12-03-2013, 12:29 PM
cayenneS2004
Sounds good thanks alot guys it just got me worried now i live in edmonton alberta where the winters can get down to -40 Celsius, i love my cayenne s it has 155km on it and running strong
Old 12-03-2013, 01:08 PM
mtnrat
mtnrat's Avatar
Mine spent most of it life in Edmonton. No issues of that kind.
Old 12-03-2013, 11:12 PM
cayenneS2004
Sounds good. Do you happen to know if they happen more on na or turbos ?
Old 12-03-2013, 11:16 PM
mcbit
mcbit's Avatar
Seems to be mostly restricted to early 955 Ss, the 955 turbos and all 957 M48 engines have oil spray piston cooling which also assists with cylinder lubrication.
Old 12-03-2013, 11:43 PM
mclaudio
mclaudio's Avatar
It happened to my 04 S. I'm only one data point, but likely not buying a 955 again. I now have a 957 V6.
Old 12-04-2013, 12:41 AM
Cole
Cole's Avatar
Talking
........and you think the VW VR6 is the solution You should never go read the VW forums! That engine has FAR more issues than the Cayenne V8!
Old 12-04-2013, 01:25 AM
cayenneS2004
Haha i heard those are pretty bad.
Does anyone know where to inquire about prices about a used engine? This uncommon problem is keeping me up at night thinking if i should keep the cayenne or not
Old 12-04-2013, 02:41 AM
endless_corners
endless_corners's Avatar
Just trade it for a turbo then. They don't fail.
Old 12-04-2013, 02:52 AM
mclaudio
mclaudio's Avatar
No need for such comments and headbanging. I never said that the VR6 is the solution.
I just stated my experience and what I have now, which is a newer (and hopefully more sorted) Cayenne. So far so good with the 957 V6 @ 61K miles, which is more than the miles on my 955 when I sold it.
Old 12-04-2013, 07:45 AM
Dan87951
Dan87951's Avatar
How much worse can it get if the V8 had catastrophic engine failure..? lol
I have two friends both with Cayenne S's and both needed engine replacements. A lot of them followed Porsche's high drain interval (as high as 20k) back in the day which I'm sure was part of the problem. I was also told there were some flaws in the piston coating and cylinder liners of this engine. How true this is I don't know.. If you want a bullet proof engine get the turbo! If you are a gambling man get the S.
Unfortunately, Porsche track record on engines hasn't been the greatest lately...
Quick Reply: Would you guys condsider V8 cayennes timebombs?
