What Did You Do To (or With) Your Cayenne Today ?
#1171
#1172
Gave her a wash:
And unboxed the new (used) summer wheels! Can’t wait:
Also finally got my suspension refresh completed and aligned properly. Took a while, but I love it. Aluminum arms, full poly bushings front and rear (Powerflex & Eurowise), all new rubber, air seals, valves, etc. She’s a real joy to drive now!
The following 3 users liked this post by PourBoi-Jay:
TRINITONY (10-24-2023)
#1174
My Cayenne has been giving me a lot of issues lately, first my driverdoor vindow stop working, broken wire, then passengerdoor found out that it will not open lock with remote, then steeringrack start leaking and needed to be replaced, when the car was up on jackstands I take away a lot of surface rust on the subframe and other places in the front, I also try to fix some corroded aircon pipe with a small leak, then I move to the back of the car and tok away rust there and now I`m changing out lower control arms both sides because it was to much rust, next thing to do is change valvebody in the gearbox due to harsh gearing but that will be done at a gerabox garage. Hopefully she is back on the road again in a few weeks.
Her I had to weld/glu all faster points that was broken.
Used liquid metal and a splitted pice of pipe to patch it up, hopefully it will not leak for a while so I can get a replasement pipe.
#1178
Came across a guy in the 6 speed GTS Facebook group that got the eBay 996/997 short shifter to work. Wish I would have thought of this before I bought/installed half of the 997 shift right solution. Gonna pull the shift right out and go this route 👌🏾
#1179
frederickcook87 (10-30-2023)
#1180
Is this the part? https://www.ebay.com/itm/273904998741
Does everything line up, or are the modifications needed to make it fit?
#1181
I'm interested in hearing more about this...I've been wanting to try to tighten up my sloppy shifter and there doesn't seem to be many upgraded options out there. I'm not really on Facebook anymore, and I don't qualify for group membership anyway since I don't have a GTS.
#1183
Cool, I will probably give it a try. It looks like the same part is available directly from China on AliExpress for about half the price too. For about $30, it seems worth it even if significant modifications end up being needed.
#1184
#1185
I opened the pano roof sunshade and found this.
Rear most glass cracked
